Graphics layer item limit /rendering problem in api version > 4.12
5385
12
12-30-2019 07:36 AM
NettaBeninson
New Contributor III
We are using graphics layers for many purposes.
When we checked v4.13, some layers appeared partially.
This happened only in big datasets.
My temp solution was to use featureLayer, and yet - it happened again in another part of our system.
I took the basic graphics example and managed to catch the point when the problem starts => more than 2205 graphic items.
I've created a simple codepen - https://codepen.io/nettaben/pen/QWwqbjy
Change  `maxItemsV413` to 2204 to 'view' the markers ==> stops working when the number is greater.
If the api version is set to 4.12 - it is possible see more than 2205 points, while in v4.13 - it is not possible.
(change in the example).
UPDATE: not working with 4.14 as well.
Attached pic - our system partial view
Codepen:#
UndralBatsukh
Hi there,
I want to let you know that this issue is fixed at 4.15. You can test the fix for the issue with the next version. Please let me know if you run into problems. Please use this test app to check the fix.
-Undral
RobertScheitlin__GISP
Netta,
   Move to 4.14 instead of 4.13.
NettaBeninson
New Contributor III
Thanks, I've tried that already - not solving the issue.
Strange. Your codepen works for me when I change to 4.14
NettaBeninson
New Contributor III
Send me a link to your new codepen maybe? did you change both css and js?
Maybe it's also dependent on the system's hardware?
anyway it's a bug....
Maybe try adding 5000 items
NettaBeninson
New Contributor III
It worked in another computer with 2205 items in v4.14 but not with 2207 items
KenBuja
MVP Esteemed Contributor
When I tried it, it broke at 3087
Seems to be hardware related. As you can see that Ken and I are able to get past the 2205 mark and you were able to on another machine.
NettaBeninson
New Contributor III
Still a bug.
UndralBatsukh
Hi there,
I am able to reproduce the issue you described and thank you for taking your time to create a simple reproducible case. We will investigate the issue and fix it.
Thank you for reporting this issue,
-Undral
