Get value of an attribute from GraphicsLayer
769
05-04-2021 07:37 AM
iepshteyn
I am adding a GraphicsLayer with markers on the map and need to know which marker was clicked. How do I get a value of an attribute when I click on the marker? Thank you
const Layer1 = new GraphicsLayer({id: 'Layer1ID'});
map.add(Layer1);
const point = {
type: "point",
longitude: -80,
latitude: 25
const attributes = { "MarkerType": "Type1" }
const pointGraphic = new Graphic({
geometry: point,
symbol: simpleMarkerSymbol,
attributes: attributes
Layer1.add(pointGraphic);
view.on(""click"", e => {
alert(need to access the above attribute MarkerType);
KenBuja
MVP Esteemed Contributor
You can use this code to get your Markertype
view.on('click',(event) =>{
  view.hitTest(event)
    .then((response) =>{
      console.log(response.results[0].graphic.attributes.MarkerType); //or attributes['MarkerType'];
BlakeTerhune
MVP Regular Contributor
hitTest() will return features from an intersecting GraphicsLayer, from which you can getAttribute() or browse with the attributes property.
Here are some hitTest() samples to check out.
KenBuja
  view.hitTest(event)
iepshteyn
Thank you Ken.
