get the extent of a featureLayer
6005
17
05-01-2017 09:11 AM
SaraEL_MALKI
Occasional Contributor II
Hi guys,
I want to get the extent of a featureLayer and Zoom to it, How I can Implement that in my code ?
function HideAllLayers() {
var layerIds = map.graphicsLayerIds;
var layer17 = map.getLayer(17); //I want to ZOOM to this Layer
var layer;
for (var i=0; i < layerIds.length; i++) {
layer = map.getLayer(layerIds[i]);
layer.hide();
$('#editModal').modal('hide'); //CLOSE THE MODAL
SaraEL_MALKI
Okay I will create a geometry Service and keep you in touch with what I've done,
thanks for your time
KristianEkenes
Since layer.fullExtent isn't totally reliable, I suggest doing the following:
featureLayer.on("load", function(){
  var query = new Query();
  query.where = "1=1";
  query.outSpatialReference = new SpatialReference(3857);
  featureLayer.queryExtent(query, zoomToExtent);
function zoomToExtent(response){
  var extent = response.extent;
  map.setExtent(extent, true);
That way you don't have to bring in GeometryService and reproject geometries. Set the outSpatialReference to match the map and the resulting extent should be good. Here's a live demo of this as well: JS Bin - Collaborative JavaScript Debugging
SaraEL_MALKI
Thanks so much for the live Demo, How can I add a zoom level in that Code ?
KristianEkenes
How do you plan to use the zoom level?
SaraEL_MALKI
I wanna zoom to that extent with a 10 level
KristianEkenes
After setting the map extent call:
map.setZoom(10);
SaraEL_MALKI
Thank you Kristian for your time
