Get mapView in another Angular Component
894
11-19-2021 10:23 AM
matteorizzi
New Contributor II
Hello! Let me explain better my issue:
- I created (in a typical way) a map View in the angular "component One":
export class MapComponent implements OnInit, OnDestroy {
  view: any;
  @ViewChild('esriMap', { static: true }) private mapViewEl!: ElementRef;
  initializeMap(): Promise<any> {
    const container = this.mapViewEl.nativeElement;
    esriConfig.portalUrl = "....";
    const webmap = new WebMap({
      portalItem: {
    const layer = new FeatureLayer({
      // URL to the service
      URL: "..."
    webmap.add(layer)
    const view = new MapView({
      container,
      map: webmap,
      zoom: 3,
      constraints: {
        minZoom: 3
    this.view = view;
    return this.view.when();
Then I need to use the "goTo" method in another angular component, let's call it "component Two".
How can I access the view defined in the component One from the component Two? Is it possible?
Thank you so much
ReneRubalcava
You can move all the JSAPI logic into an injectable service and use that service in components you want to be able to access it.
import { Injectable } from '@angular/core';
import WebMap from '@arcgis/core/WebMap';
import MapView from '@arcgis/core/views/MapView';
import Bookmarks from '@arcgis/core/widgets/Bookmarks';
import Expand from '@arcgis/core/widgets/Expand';
@Injectable({
  providedIn: 'root'
export class MapService {
  public view: MapView | null = null;
  constructor() {}
  async createMap(container: HTMLDivElement) {
      portalItem: {
      container,
      map: webmap
    const bookmarks = new Bookmarks({
      view,
      // allows bookmarks to be added, edited, or deleted
      editingEnabled: true
    const bkExpand = new Expand({
      view,
      content: bookmarks,
      expanded: true
    // Add the widget to the top-right corner of the view
    view.ui.add(bkExpand, 'top-right');
    // bonus - how many bookmarks in the webmap?
    webmap.when(() => {
      if (webmap.bookmarks && webmap.bookmarks.length) {
        console.log('Bookmarks: ', webmap.bookmarks.length);
      } else {
        console.log('No bookmarks in this webmap.');
    this.view = view;
