get coordinates of polyline
1175
6
07-24-2018 06:30 AM
MRReddy
In a map, i have several color polylines(indicating different status)
i know to write a condition to get all polylines values on map, but suppose if i want only blue color line polyline geometry,(how to write a condition to filter only blue polyline geometry), I tried several ways and got stuck here.
Any help appreciated
Thank you
RobertScheitlin__GISP
Malla,
   So you have to use GeometryService to project the Location_CenterPoint to web mercator if you are going to create a geodesic circle.
https://developers.arcgis.com/javascript/3/jsapi/geometryservice-amd.html#project
Malla,
   You have some attribute condition statement that makes the line either red or blue so you have to query the layer using that same attribute condition. to get just one color of lines.
MRReddy
Hi robert #robert scheitlin
i did union of those polylines and extent and getcenter
now in getcenter()-> X and Y both values are positive. I believe x should be negative and when i load with both positive coordinates, nothing happening
But if i change spatial reference
i got below error
 "Creating a geodesic circle requires the center to be specified in web mercator or geographic coordinate system"
any suggestions
Thank you
MRReddy
getting circle here, but i verified point in google maps, (value is correct), but it loading somewhere
Malla,
  These questions seem to have little to do with your original question... So which question do you want answered and what does you code look like?
MRReddy
below is my code
 var returngeometries_Site = geometryEngine.union(Site_CenterPoint);    //wkid 2881 latest wkid 2881
var extent = returngeometries_Site.getExtent();
var cmnpoint = extent.getCenter();
var Location_CenterPoint = new Point(cmnpoint .x, cmnpoint .y);
sending Location_CenterPoint  in to circle
Malla,
