Geoprocessing service Not accepting Post parameters properly
907
5
03-03-2022 09:05 PM
pragati224
New Contributor III
Hi Everyone,
I am facing a weird issue. I am accessing a geoprocessing service in my web application, which is built on a custom python script. The script has some user input parameters, which when running from web application is sending them as parameters.
I can verify parameters as correct by using Developer tools, but the geoprocessing service accepts all parameters except one and returns result on default value of the python script.
However, when I open the geoprocessing rest service exceute task as a stand alone on browser, use same parameters as shown in Dev tools and run it; it creates proper result.
Also, I am using ArcGIS JS 3.39, can I use Get method instead of Post method for execute command of geoprocessing service and tie it is parameter variables.
If it's required I can share the code references.
Regards
Noah-Sager
Hi @pragati224, a code snippet (or even better a reproducible test app that clearly demonstrates the issue) and URL to the GP service would help troubleshoot here.
AroopChakraborty1
Hi Noah,
Sorry for late reply!
I am colleague of Pragati. I have shared some screenshots to clarify the workflow @Noah-Sager . I have attached a word file with the screenshots:
If you wish I can share the script on email to you.
Regards!
Aroop Chakraborty
Noah-Sager
Thank you @AroopChakraborty1. However, I can't do much troubleshooting with that you shared. A code snippet from the 3x app, (or even better a reproducible test app that clearly demonstrates the issue) and URL to the GP service would help troubleshoot here.
AroopChakraborty1
Hi @Noah-Sager Actually while creating the document and carefully checking the input parameters passed in the application, I found the issue. Its resolved. The issue was wrong parameter name being passed. That's why it was taking in default values. A silly mistake!
Noah-Sager
Ha, I know how that goes. Sounds good, glad it's resolved now.
