GeometryService is not a constructor
1521
6
08-31-2022 02:39 PM
LoriMcCormack1
New Contributor III
I am trying to create a graphic on the map and grab its Latitude and Longitude values.  To do so, I need to project from State Plane to WGS84 (wkid=4326).
1. When I try to create a new GeometryService, I get an error saying "GeometryService is not a constructor".
In my require statement, I'm using
"esri/rest/geometryService",
"esri/rest/support/ProjectParameters",
In my function statement, I'm using
GeometryService,
ProjectParameters,
This is the line that causes the error "GeometryService is not a constructor":
const myGeometryService = new GeometryService("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
2.  If I change my function statement to lower case g:
geometryService,
ProjectParameters,
This is the line that causes a different error "Identifier 'geometryService' has already been declared"
const myGeometryService = new geometryService("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
What am I doing wrong?
Note:  I've also tried URL "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/Geometry/GeometryServer"
ReneRubalcava
The snippet is incorrect and will be updated in next release.
require([
], function(geometryService, ProjectParameters) {
  const params = new ProjectParameters({
    geometries: [point],
    outSpatialReference: outSpatialReference,
    transformation: transformation
  geometryService.project(url, params).then( ... );
This can also be written as:
import { project } from "@arcgis/core/rest/geometryService";
import ProjectParameters from "@arcgis/core/rest/support/ProjectParameters";
The snippet assumes you are using ESM, which should only import the project method.
ReneRubalcava
It's not a class, so you don't create a new instance. It has methods that you just pass the url and options. The old Task based classes were removed at 4.24 after being deprecated for a few releases.
https://developers.arcgis.com/javascript/latest/api-reference/esri-rest-geometryService.html
References:
https://www.esri.com/arcgis-blog/products/js-api-arcgis/developers/rest-is-up-to-the-task/
https://developers.arcgis.com/javascript/latest/release-notes/#breaking-changes
NLA-ICTNLA-ICT
New Contributor II
Case sensitivity:
Your require statements shout be:  "esri/rest/GeometryService",
Not:  "esri/rest/geometryService",
LoriMcCormack1
New Contributor III
1. The documentation shows the require statement as camelcase geometryServiceRequireFor424.png
2. I realize that it changed in 4.19, but the example in the API reference (shown below) says I need the new GeometryService.  So, in the example below from the API Reference, the const geomSer = new GeometryService(...); is wrong? By removing the new GeometryService() statement, the error went away, as long as geometryService was set to camelcase. geometryServiceProjectExample.png
3. How do I get "project" to be recognized?  Now I am getting an error with the code below, saying "ReferenceError:  project is not defined"
    const urlGeomServ = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/Geometry/GeometryServer";
    view.when(() => {
        view.on("click", function (event) {
            var outSR = new SpatialReference(4326);
            var geomSerParams = new ProjectParameters({
                geometries: [event.mapPoint],
                outSpatialReference: outSR
             project(urlGeomServ, geomSerParams).then(function (projectedPoints) {
                 pt = projectedPoints[0];
                 ptLatitude = pt.y;
                 ptLongitude = pt.x;
                 createPointGraphic(ptLongitude, ptLatitude, "AddPost");
ReneRubalcava
require([
KenBuja
MVP Esteemed Contributor
Could you post your full require/function section? This can be caused by a mismatch between the require modules and the function arguments.
LoriMcCormack1
New Contributor III
I was able to fix the code by simply adding "geometryService." in front of the "project" statement, as shown in the first snippet in ReneRubalcava's response above.
require([
    view.when(() => {
             geometryService.project(urlGeomServ, geomSerParams).then(function (projectedPoints) {
                 ptLatitude = pt.y;
                 ptLongitude = pt.x;
Thank you all for responding so quickly to help me identify the problem.
I've only used the import statements in python code, so I wasn't familiar with that usage in the ArcGIS API for JavaScript.  Great to know!
