Hi all,
I'm successfully generating buffered polygons for input polyline features and the requirement has changed to show "square ends" rather than the rounded ends the current buffer is creating.
Is there a simple parameter I'm missing for the BufferParameters() of a call to the geometryService.Buffer()?
Thanks for any input!
//populate the polyline geometries
var features = layer.featureSet.features;
arrayUtils.forEach(features, lang.hitch(this, function (feature) {
this.shapeGeometries.push(new Polyline(feature.geometry));
////setup the buffer parameters
var params = new BufferParameters();
params.distances = [buffDist]
params.outSpatialReference = map.spatialReference;
params.bufferSpatialReference = new esri.SpatialReference({ "wkid": "102258" }); //spatial reference info https://spatialreference.org/ref/esri/nad-1983-harn-stateplane-florida-east-fips-0901/
params.unit = GeometryService["UNIT_METER"];
params.geometries = this.shapeGeometries;
esriConfig.defaults.geometryService.buffer(params, showBuffer);
//show bufferedGeometries and then continue processing to union them
function showBuffer(bufferedGeometries) {
var symbol = new SimpleFillSymbol(
SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(
SimpleLineSymbol.STYLE_SOLID,
new Color([255, 0, 0, 0.65]), 2
new Color([255, 0, 0, 0.35])
var bFeatures = [];
array.forEach(bufferedGeometries, function (geometry) {
var graphic = new Graphic(geometry, symbol);
bFeatures.push(graphic)
Solved! Go to Solution.
James,
There is not a square end parameter for buffering, so you are not missing anything.
James,
