Floating/draggable PopUp window
7581
10
08-27-2012 11:18 PM
demdeberanz
Hi everybody,
   how to make a popup window floating and draggable?
Thank you very much for helping me.
DavideLimosani
Occasional Contributor II
demdeberanz
you can try with this:
http://www.arcgis.com/home/item.html?id=cf41ba2f1798462f9386efdd674f36ba
Thank you very much for your quick reply, dlimos. I've already used the dojo floating pane but how to automatically bind the feature information to the pane?
Thank you.
__Rich_
Always interested to see what people have tried for themselves so far...
..but anyway, if you have a widget that already does most of what you want e.g. display attributes, then have you considered making that widget draggable?  (if the widget is suitable, - might not be)
For example, using dojo-dnd-moveable?
Or another approach could be to combine a container widget that does all the dragging stuff with a widget that does the display stuff, i.e. put one inside the other.
Or you could try and write your own either from scratch or start with an existing widget and extend it.
You have to decide, after research, which is the better approach for your requirements/ability etc.
demdeberanz
Dear geos_rfleet,
   I'm glad to you for the reference I managed to find the solution, simply declaring a variable as a dnd.Moveable(domNode).
Thank you very much.
ShaunWeston
Has anyone got this to work, I've tried setting it up like this:
        var popup = new esri.dijit.Popup(popupOptions, dojo.create("identifyDiv"));
        var dnd = new dojo.dnd.Moveable(dojo.byId("identifyDiv"));
and added an identifyDiv tag to the html page, but still not moveable?
ShaunWeston
Ah, figured it out, just need to reference the div rather than create:
        popup = new esri.dijit.Popup(popupOptions, "identifyDiv");
JeffJacobson
require([
    "esri/arcgis/utils",
    "dojo/dnd/Moveable"
], function (arcgisUtils, Movable) {
    "use strict";
    var mapId = "bc6e18b0c332407e800c234de472939f"; // Replace with your own map ID from ArcGIS.com.
     * Makes the popup draggable.
     * @returns {dojo/dnd/Movable}
    function makePopupDraggable(){
        var popupDiv = document.querySelector(".esriPopup");
        var dnd;
        if (popupDiv) {
            dnd = new Movable(popupDiv);
        // TODO: Figure out how to make the little arrow point the right way after dragging.
        return dnd;
    arcgisUtils.createMap(mapId, "map", {
        usePopupManager: true,
        mapOptions: {
            center: [-120.80566406246835, 47.41322033015946],
            zoom: 7,
            minZoom: 7
    }).then(makePopupDraggable);
RobertKirkwood
This works, but then you cannot select any text inside the popup. is there a way to work around that?
RobertKirkwood
