Filter WMSLayer using CQL_FILTER and customLayerParameters
1550
10-02-2020 09:48 AM
julienrobitaille
I am trying to get the CQL_FILTER working in order to filter WMSLayer filtered. I am using the customLayerParameters to do that:
            const layer_oiseaux = new WMSLayer({
                url: "https://ogsl.ca/geoserver/eccc_atlas/wms?",
                sublayers: [
                        popupEnabled: true,
                        queryable: true,
                visible: true,
                customLayerParameters: [{
                    CQL_FILTER: "shape_leng>1000"
            map.add(layer_oiseaux);
Hoever, nothing is happening, the parameter CQL_FILTER doesn't seem to work. Is this normal?
Is there another way to filter WMS layers?
Thank you!
BayramÜçüncü1
Is your geometry field name "shape_leng" or "shape_length"?
julienrobitaille
I actually found what was the problem (it was actually just the brackets that were not supposed to be there). When I found the issue, I set the discussion as "obsolete".
But thanks anyway to have given it a try!
Julien
