FeatureTable not loading rows
306
03-19-2019 03:07 PM
PhilipKnight1
When using standard javascript and standard examples of AMD, my feature table loads just fine, but when using this inside typescript the rows just never load. It also never makes a call to retrieve the data. I also added an on error event as referenced in the code below and it never gets thrown. I also have many other controls that run just fine and I receive no javascript errors. What can I do diagnose the issue further?
code setting up featureTable:
this._myFeatureTable = new FeatureTable({
showFeatureCount: true,
showColumnHeaderTooltips: true,
showAttachments: true,
syncSelection: true, // only allows selection from the table to the map
zoomToSelection:
false, //auto zooming can be kind of annoying when you are selecting from the map
gridOptions: {
allowSelectAll: true,
allowTextSelection: true,
featureLayer: featureLayer,
//outFields: ["HydID,StreetName,OBJECTID"],
outFields: ["*"],
map: this._myMap,
editable: false
divID);
if (onLoaded != null) {
this._myFeatureTable.on("refresh",
(e) => {
onLoaded();
}); //need to do this or else the row may not actually this.get highlighted, this is because the table may not actually be loaded when we go to select yet
this._myFeatureTable.on("load", function(evt){
console.log("load event - ", evt);
this.refresh();
this._myFeatureTable.on("error", function(evt){
console.log("error event - ", evt);
this._myFeatureTable.startup();
code for instantiating typescript:
requirejs.config({
waitSeconds: 0,
baseUrl: "@(Url.Content("~/Scripts/app/"))",
paths: {
GIS: "./GIS"
packages: [{
main: 'main'
main: 'main'
main: 'main'
deps: ['dojox/main', 'dojo/main', 'dijit/main']
require(["GIS/GIS"],
function(GIS) {
gisModule = new GIS("@(JsonConvert.SerializeObject(gisViewData))");
Tags (3)
