FeatureTable 4.x Questions
767
11-09-2020 12:27 PM
JoshObrecht1
I am just starting to use version 4 of the Javascript API and had a couple of FeatureTable questions that I could not find the answer. It may be possible these aren't implemented yet.
1. Is there a way to remove the checkbox column? I just want the columns of data.
2. Is there a way to set the width of the columns?
KavishGhime3
Hello @JoshObrecht1,
  1. Checkbox column:
  2. Width of column:
You can contact Support Services if you want to log enhancements on above issues.
mheroui
Hello JoshObrecht1,
To remove checkbox column in FeatureTable just add the following line:
visibleElements: { selectionColumn: false } when you create the new FeatureTable.  See link bellow: http://gis.kaiquan.com.cn/latest/sample-code/sandbox/index.html?sample=widgets-featuretable
