Features within 300 feet of selected feature
735
02-19-2021 10:30 AM
khanley
New Contributor II
I see a lot of examples of queries using a circle to find features within a given distance of a center point, but I have yet to be able to find an example of a query done using a feature to find all features within a given distance.
Can someone point me in the right direction? I'm sure it's very similar to a circle but something just isn't clicking in my head.
Thank you.
RobertScheitlin__GISP
Here is a mashup of the Select with Feature Layer and Geometry Service - Buffer samples. It querys the census block layer and buffers the results and uses that buffer to query census block points that intersect the buffer.
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Select with feature layer</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.35/dijit/themes/tundra/tundra.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.35/esri/css/esri.css">
    <style>
      html, body, #mapDiv {
        padding: 0;
        margin: 0;
        height: 100%;
      #messages{
        background-color: #fff;
        box-shadow: 0 0 5px #888;
        font-size: 1.1em;
        max-width: 15em;
        padding: 0.5em;
        position: absolute;
        right: 20px;
        top: 20px;
        z-index: 40;
    </style>
    <script src="https://js.arcgis.com/3.35/"></script>
    <script>
      var map;
      require([
        "esri/map", "esri/layers/FeatureLayer",
        "esri/tasks/query", "esri/tasks/GeometryService",
        "esri/tasks/BufferParameters",
        "esri/graphic", "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/renderers/SimpleRenderer",
        "esri/config", "esri/Color", "dojo/dom", "dojo/domReady!"
      ], function(
        Map, FeatureLayer,
        Query, GeometryService, BufferParameters,
        Graphic, SimpleMarkerSymbol,
        SimpleLineSymbol, SimpleFillSymbol, SimpleRenderer,
        esriConfig, Color, dom
        esriConfig.defaults.geometryService = new GeometryService("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        map = new Map("mapDiv", {
          basemap: "streets",
          center: [-95.249, 38.954],
          zoom: 14,
          slider: false
        // Add the census block points in on demand mode. An outfield is specified since it is used when calculating   the total population falling within the one mile radius.
        var featureLayer = new FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/0",{
          outFields: ["POP2000"]
        // census block polygon layer
        var featureLayer2 = new FeatureLayer("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/1",{
          outFields: ["FIPS"]
        // Selection symbol used to draw the selected census block points within the buffer polygon
        var symbol = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_CIRCLE,
          12,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_NULL,
            new Color([247, 34, 101, 0.9]),
          new Color([207, 34, 171, 0.5])
        featureLayer.setSelectionSymbol(symbol);
        // Make unselected features invisible
        var nullSymbol = new SimpleMarkerSymbol().setSize(0);
        featureLayer.setRenderer(new SimpleRenderer(nullSymbol));
        map.addLayer(featureLayer);
        var blockSymb = new SimpleFillSymbol(
          SimpleFillSymbol.STYLE_NULL,
            SimpleLineSymbol.STYLE_SHORTDASHDOTDOT,
            new Color([105, 105, 105]),
          ), new Color([255, 255, 0, 0.25])
        var block, buffer;
        //setup the buffer parameters
        var params = new BufferParameters();
        params.distances = [0.5];
        params.outSpatialReference = map.spatialReference;
        params.unit = GeometryService["UNIT_STATUTE_MILE"];
        setTimeout(function(){
          var query2 = new Query();
          query2.where = "FIPS = '200450004001'";
          query2.returnGeometry = true;
          query2.outSpatialReference = map.spatialReference;
          featureLayer2.queryFeatures(query2, function(response){
            map.graphics.clear();
            block = response.features[0].geometry;
            var graphic = new Graphic(block, blockSymb);
            map.graphics.add(graphic);
            params.geometries = [block];
            esriConfig.defaults.geometryService.buffer(params, showBuffer);
        }, 2000);
        function showBuffer(bufferedGeometries){
            var symbol = new SimpleFillSymbol(
                SimpleLineSymbol.STYLE_SOLID,
                new Color([255,0,0,0.65]), 2
                new Color([255,0,0,0.35])
            buffer = bufferedGeometries[0];
            var graphic = new Graphic(buffer, symbol);
            var query = new Query();
            query.geometry = buffer.getExtent();
            featureLayer.queryFeatures(query, selectInBuffer);
        function selectInBuffer(response){
          var feature;
          var features = response.features;
          var inBuffer = [];
          // Filter out features that are not actually in buffer, since we got all points in the buffer's bounding box
          for (var i = 0; i < features.length; i++) {
            feature = features[i];
            if(buffer.contains(feature.geometry)){
              inBuffer.push(feature.attributes[featureLayer.objectIdField]);
          query.objectIds = inBuffer;
          // Use an objectIds selection query (should not need to go to the server)
          featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(results){
            var totalPopulation = sumPopulation(results);
            var r = "";
            r = "<b>The total Census Block population within the Census Block buffered by .5 mi is <i>" + totalPopulation + "</i>.</b>";
            dom.byId("messages").innerHTML = r;
        function sumPopulation(features) {
          var popTotal = 0;
          for (var x = 0; x < features.length; x++) {
            popTotal = popTotal + features[x].attributes["POP2000"];
          return popTotal;
    </script>
  </head>
  <body>
    <span id="messages">Wait for FIPS = '200450004001' Query to execute...</span>
    <div id="mapDiv"></div>
  </body>
</html>
<!DOCTYPE html>
<html>
  <head>
    <style>
        padding: 0;
        margin: 0;
        height: 100%;
      #messages{
        font-size: 1.1em;
        max-width: 15em;
        padding: 0.5em;
        position: absolute;
        right: 20px;
        top: 20px;
        z-index: 40;
    </style>
    <script>
      var map;
      require([
      ], function(
        Map, FeatureLayer,
          basemap: "streets",
          zoom: 14,
          slider: false
          outFields: ["FIPS"]
          12,
        var block, buffer;
        }, 2000);
          var feature;
          var inBuffer = [];
            var r = "";
          var popTotal = 0;
          return popTotal;
    </script>
  </head>
  <body>
  </body>
</html>
