FeatureLayer Source
2067
03-29-2019 12:59 PM
by Anonymous User
Not applicable
Greetings,
I'm trying to use featureLayer.source to create a feature layer with JSON. I create my featureLayer with an empty source and renderer and then try to add JSON data to it later. For some reason I'm getting the error:
            "Source modifications will not propagate after layer has been loaded. Please use .applyEdits() instead"
I create the featureLayer like so:
  let fl = new FeatureLayer({
          popupTemplate: layer.popupTemplate,
          fields:layer.fields,
          objectIdField:"FACILITYID",
          geometryType: "point",
          source:[]
        fl.minScale = layer.minScale;
        console.log('fl.id: ' + fl.id)
        const arcade = ` IIf($feature.NUM >100, true, false)`
        var renderer = {
          type: "unique-value", // autocasts as new UniqueValueRenderer()
          valueExpression: arcade,
          valueExpressionTitle: "Adoption Status",
          uniqueValueInfos: [
              value: true,
              symbol: self.createSymbol("#00c3ff"),
              label: "adopted"
              value: false,
              symbol: self.createSymbol("#ff002e"),
              label: "unadopted"
        mapView.map.add(fl)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Later on I try to add data to the feature layer using the source.add method like so:
let fl = self.state.mapView.map.findLayerById(layer.id)
fl.source.add({"attributes":{"FACILITYID":"DP76415003","INSTALLDATE":-2208970800000,"INLETTYPE":"Pipe","ACCESSDIAM":0,"adopted":"false"},"geometry":{"type":"point","x":-8769067.07037968,"y":4271765.250156212}})
the fl.source.add method is what is giving me the error.
Does anyone notice anythign that I'm doing wrong?
Thanks, Tyler
ReneRubalcava
You can only add features via the source when you first create the client-side FeatureLayer. All subsequent updates need to happen via the applyEdits method just like you were editing the layer. There is a code snippet in the documentation. https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-FeatureLayer.html#applyEdi...
ReneRubalcava
by Anonymous User
Not applicable
That was what I needed. Thank you for the info!
Tyler
UndralBatsukh
Hi there,
Rene answered already. Just adding this link for more information.
