FeatureLayer Promise Doesn't Resolve
3927
12-12-2017 09:56 AM
JaredGasco
New Contributor II
Hello All,
I'm creating FeatureLayer objects from SubLayer objects in order to use them as sources in a Search widget. One of the FeatureLayer objects seems to work properly as a source while the other two don't. I originally added them as sources without using the then method callback on the FeatureLayer objects. I then tried adding them within the then method callback and none of them got added because the Promises never resolved. I then wrote some test code with a completely different MapServer and the same thing happens.
Does anyone know why the FeatureLayer Promise isn't resolving?
UndralBatsukh
Hi Jared,
Looking at your code, you are not adding the featureLayer to the view so it is the developer's responsibility to load the layer. Please take a look at the doc for the FeatureLayer.load():
https://jscore.esri.com/javascript/latest/api-reference/esri-layers-FeatureLayer.html#load
fl.load().then(function(){
 console.log("layer loaded");
Hope this helps,
-Undral
UndralBatsukh
Hi Jared,
Hope this helps,
-Undral
ThomasSolow
Occasional Contributor III
The Feature Layer won't attempt to load unless you add it to the map or manually load it.
So try returning new FeatureLayer({ ... }).load(), or add the Feature Layer to your map before returning it.
I should note, I'm not sure if a sublayer in a MapImageLayer can be a FeatureLayer.
KristianEkenes
You can use any feature service or map service endpoint as a data source for feature layer.
JaredGasco
New Contributor II
Thanks everyone. Invoking the load method before the then method solved my issues.
