exportImage with bounding box
959
06-28-2021 11:30 PM
Sendhil
New Contributor II
I am using the ArcGIS API for JavaScript for react. I am using an imageServer layer.
I see on load there are calls made to "ImageServer/exportImage" with a bounding box parameter while loading , zooming the map.
I would like to understand why this call is being made , how can I avoid this call.
I was looking for some architectural documents to understand the behavior of the map viewer.
Sendhil
ReneRubalcava
You're right, it's not cacheable, but the bounding box defines how to clip the image. You can't get an image without it.
ReneRubalcava
The exportImage endpoint is how the image is queried to load in the map.
https://developers.arcgis.com/rest/services-reference/enterprise/export-image.htm
There's no way to avoid it while using an ImageService layer, it's how the image is displayed
Sendhil
New Contributor II
Thank you. Wondering why there is a request made with the bounding box.
Is the map viewer initiating this request?
Trying to avoid this call since this could be a non cacheable request / response.
Regards,
Sendhil
ReneRubalcava
Sendhil
New Contributor II
Thank you.
I did try a sample from https://developers.arcgis.com/javascript/latest/sample-code/layers-imagerylayer/
Intro to ImageryLayer | Sample | ArcGIS API for JavaScript 4.19
This has a simple call to the imageryLayer and I could see calls made to imageryServer/exportImage with bounding box parameter
Regards,
Sendhil
jhonsnow
Howdy,
I'm also involving the ArcGIS Programming interface for JavaScript for respond. I'm utilizing an imageServer layer.
I see on load there are calls made to "ImageServer/exportImage" with a jumping box boundary while stacking , zooming the guide.
I might want to comprehend the reason why this call is being made , how might I keep away from this call.
I was searching for a few engineering reports to grasp the way of behaving of the guide watcher.
Much obliged,  best boxes
