Example of how to use the PrintTask's customTextElements property
3814
02-27-2013 02:03 PM
OscarShell
New Contributor II
Hello.
Can anyone share an example of how to use the PrintTask's customTextElements property?  Can I pass in a dojo textbox and it's value?
Thanks!
JerrySimmons_GISP
New Contributor III
you can modify the out of the box mxd's installed with ArcGIS server (on the server they are located in C:\Program Files\ArcGIS\Server\Templates\ExportWebMapTemplates) instead of publishing you own.  Just add a text element (insert>text) then open its properties and click on the "Size and Poistion" tab and give it an Element Name (ex: infoDetails) this will be referenced in your template parameters.
In the below example I'm referencing the customTextElement infoDetails and passing in a string (details) that I generated.  This also shows you how to access multiple customTextElements.
template.layoutOptions = {
        titleText: "My Print page",
        customTextElements: [{ infoHeader: headers }, { infoDetail: details }],
hope this helps.
JerrySimmons_GISP
New Contributor III
hope this helps.
RobertKirkwood
Occasional Contributor III
Thanks! Worked great
