I try to register a token I have created, using IdentityManager.registerToken()
as it is suggested in MapImageLayer | API Reference | ArcGIS API for JavaScript 4.4 and
IdentityManager | API Reference | ArcGIS API for JavaScript 4.4
but i get the error, in console , "esriId.registerToken is not a function". What's wrong? thank you, Kostas ...var esriRequireModules = [ "esri/Map", "esri/request", "esri/geometry/support/webMercatorUtils", "esri/geometry/Point", "esri/widgets/Search", "esri/Graphic", "esri/symbols/PictureMarkerSymbol", "esri/PopupTemplate", "esri/layers/GraphicsLayer", "esri/layers/FeatureLayer", "esri/layers/MapImageLayer", "esri/layers/GroupLayer", "dojo/on", "dojo/domReady!", "esri/identity/IdentityManager" ]; var esriRequireCallback = function( Map, esriRequest, webMercatorUtils, Point, Search, Graphic, PictureMarkerSymbol, PopupTemplate, GraphicsLayer, FeatureLayer, MapImageLayer, GroupLayer, on, esriId ) {...
esriId.registerToken({ server : ... token : ... expires : ... });...
esriLoader.require(esriRequireModules, esriRequireCallback);
Your module paths and module variables need to appear in the same order.
"esri/Map", // 0
"esri/request", // 1
"esri/geometry/support/webMercatorUtils", //2
"esri/geometry/Point", //3
"esri/widgets/Search",//4
"esri/Graphic",//5
"esri/symbols/PictureMarkerSymbol",//6
"esri/PopupTemplate",//7
"esri/layers/GraphicsLayer",//8
"esri/layers/FeatureLayer",//9
"esri/layers/MapImageLayer",//10
"esri/layers/GroupLayer",//11
"dojo/on",//12
"dojo/domReady!",//13
"esri/identity/IdentityManager"//14
Map,//0
esriRequest,//1
webMercatorUtils,//2
Point,//3
Search,//4
Graphic,//5
PictureMarkerSymbol,//6
PopupTemplate,//7
GraphicsLayer,//8
FeatureLayer,//9
MapImageLayer,//10
GroupLayer,//11
on,//12
esriId//13
So in your case, esriId is actually the domReady object. you can switch the two paths in your require array, or add another variable in your callback to fix.
"esri/Map", // 0
"esri/Graphic",//5
"dojo/on",//12
Map,//0
esriRequest,//1
Point,//3
Search,//4
Graphic,//5
PopupTemplate,//7
GraphicsLayer,//8
FeatureLayer,//9
MapImageLayer,//10
GroupLayer,//11
on,//12
esriId//13
