ESRI JS API Sample: Viewshed broken
738
12-08-2020 02:19 AM
NicolasGIS
Occasional Contributor III
Hello JS API team,
Just noticed that viewshed samples are broken in 3.X and 4.X:
https://developers.arcgis.com/javascript/latest/sample-code/geoprocessing-viewshed/index.html
https://developers.arcgis.com/javascript/3/samples/gp_viewshed/
The following error is logged in the console:
Error executing tool. Viewshed :
You must enter at least ONE observer point↵↵Failed to execute (Viewshed).↵Failed to execute (Viewshed).↵Failed to execute (Viewshed)
Cheers
KenBuja
MVP Esteemed Contributor
Are you still getting that error? I'm not seeing it on either sample in Chrome, Firefox, or Edge.
KenBuja
NicolasGIS
Indeed, it is solved !
LibertadChapinal
New Contributor II
The solution is down and also the sample codes, have you got any example working?
