ESRI JS API 4.X : basemapToogle Widget from webmap, thumbnail not loaded
672
07-19-2018 11:19 AM
NicolasGIS
Occasional Contributor III
Using ArcGIS JS API 4.8, when I load a webmap and configure a second basemap from a portalItem webmap, I noticed that the thumbnail of the second basemap is not displayed at startup. You need to toogle it once:
Demo
Using a webpack build, I even do not get the main webmap displayed at start up. I need to toogle several times the widget so that thumbnails get loaded.
Any idea ?
Thanks !
Tags (1)
NicolasGIS
Not a bug ? Something wrong made on my side ?
Cheers
NicolasGIS
Same issue with 4.12
ReaganSenoron
New Contributor II
Have you found solution to this? I have similar issue. Thanks.
NicolasGIS
Nop. I ended up manually setting the thumbnails URL
