ESRI JS API 4.17: error adding graphic
961
10-16-2020 10:33 PM
NicolasGIS
Occasional Contributor III
Hello,
After upgrading my application to 4.17, I just noticed an error after adding graphic to mapView:
GraphicError
You can easily reproduce the issue using the following sample "Add graphics (SceneView)":
ArcGIS API for JavaScript Sandbox
and replace sceveView by mapView:
CodePen
Thanks for listening !
/cc Noah Sager
Tags (3)
UndralBatsukh
Hi there,
I am able to reproduce the issue. The error thrown because the graphic geometries are null at the initial scale of your app. If you zoom in you will see all the geometries. The console error do not affect the functionality of your app. With this said, we created an issue to remove this error.
Hope this helps,
-Undral
UndralBatsukh
Hi there,
Hope this helps,
-Undral
NicolasGIS
Thanks for reply !
Happy to read that it is logged
UndralBatsukh
Hi there,
This issue is fixed at 4.17. You can verify it using the test app you provided.
-Undral
NicolasGIS
Thanks for the reply.
Indeed, CDN looks fixed. But I still have the issue using arcgis-webpack-plugin.
Thanks
