ESRI JS API 4.11: Cannot destroy Editor widget
711
04-12-2019 10:44 AM
NicolasGIS
I just noticed that the Editor widget cannot be destroyed: an error occurs and the widget is not destroyed:
Codepen
Nicolas
UndralBatsukh
Hi there,
Thank you for reporting this issue. We will address it in our next release.
-Undral
KenBuja
However, if you try to use the editor after destroying it, it's not working. Adding in a console.log(editor) after destroying it will give you
TypeError: null has no properties
You just have to manually remove the editor from the view.ui before destroying it.
setTimeout(() => {
  alert("Editor should be destroyed");
  view.ui.remove(editor);
  editor.destroy();
  console.log(editor);
}, 10000);‍‍‍‍‍‍
NicolasGIS
Thanks for the suggestion Ken Buja‌ but then clicking on the map returns an error because the widget is not properly destroyed
UndralBatsukh
Hi there,
-Undral
NicolasGIS
Hi Undral Batsukh‌,
Thanks for the update!
