Editor Widget Text Area Inputs
940
11-19-2021 04:16 PM
dcarson1661
New Contributor III
Hello,
I’m working in API V 4.20. I’m trying to make a text-area input in the Editor Widget. I currently have this implemented using the (editorType : “text-area”) property, but I’m experiencing some behavior I don’t understand. I get a text area field, but it will only expand horizontally when grabbing the handle shown below.
I noticed that the editorType property has been deprecated, but I have not been able to achieve the same effect using the suggested workflow below. Does anyone know how to allow the text area to expand vertically as well? Or how to implement TextAreaInput?
Thank You!
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-FeatureForm-FieldConfig.h...
“editorType String
Since: ArcGIS API for JavaScript 4.10
Deprecated since version 4.16
The type of editor to use for string field types. Possible values are in the table below. The preferred way to set the editor type is via TextAreaInput or TextBoxInput classes set within the field element of a FeatureForm's template.”
Here is my current Editor Widget
          // Edit widget
          const editor = new Editor({
          view: view,
          container: "sidePanel",
          allowedWorkflows: ['create','update'],
          layerInfos: [{
            layer: 'layer,
            fieldConfig: [
            label: "Location",
            editorType: "text-area"
      deleteEnabled: false
dcarson1661
New Contributor III
I got this figured out. Adding the below to my CSS allowed for resizing in both directions.
        .esri-feature-form__input {
        resize: both !important;
JeffreyWilkerson
Occasional Contributor III
When I setup my Editor at 4.20, I'm using the 'stringFieldOption' attribute to set the field type to "text-area", which I think predetermines the editor to adjust to it.
    view: view,
    allowedWorkflows: ["update"], // allows only updates and no adds
    layerInfos: [{
        layer: busStopLayer,
        fieldConfig: [
            label: "Location",
            initialState: "collapsed",
            description: "General location information",
            fieldConfig: [
                { name: "Location", label: "Location" },
                { name: "Owner", label: "Owner" }
            label: "Structure",
            description: "Information about the bus stop",
            fieldConfig: [
                { name: "StopType", label: "Type of Stop" },
                { name: "Condition", label: "Condition Assesment" },
                { name: "ConditionDate", label: "Date of Condition Assessment", formatter: formatTimestamp },
                { name: "Comments", label: "Add any general comments", stringFieldOption: "text-area" }
        enabled: true
    container: "editDiv",
view.ui.add("editDiv", { position: "top-right", index: 2 });
dcarson1661
New Contributor III
