Editor widget does not work (it appears but not functional), pleasehelp!
1479
07-14-2021 11:40 PM
AbirELTAIEF1
Please, could you guide me , I have a problem with the widget Editor (arcgis-JS-API),
I need to loop through all my featurelayers (in my map), to apply the Editor widget "esri/widgets/Editor", to the layers in my map (uploaded from Arcgis server online), because I need to add (edit, delete, update capibilities to my featurelayers in the same document) : could you please guide me, here you find my code, I have this error message, when I run it
The error message: (you find the screenshots, below, after the code)
Uncaught (in promise) TypeError: Cannot read property 'uid' of undefined
    at w.get (Editor.js:2569)
    at Object.a.runTracked ((index):148)
    at f.k.getComputed ((index):143)
    at p.e.get ((index):136)
    at c ((index):126)
    at Object.f [as valueOf] ((index):126)
    at (index):163
    at c.u [as _notify] ((index):196)
    at c.g.onCommitted ((index):198)
And here the code:
<html lang="en">
<head>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<meta http-equiv="X-UA-Compatible" content="ie=edge">
<link rel="stylesheet" href="https://js.arcgis.com/4.20/esri/themes/light/main.css">
<script src="https://js.arcgis.com/4.20"></script>
<title>Edting by ArcGIS Server Online</title>
<style>
html,
body,
#viewview {
padding: 0px;
margin: 0px;
height: 100%;
width: 100%;
} #formDiv {
width: 100%;
} .esri-item-list__scroller {
overflow-y: visible;
} .list-heading {
font-weight: normal;
margin-top: 20px;
margin-bottom: 10px;
color: #323232;
} .or-wrap {
background-color:white;
height: 1px;
margin: 2em 0;
overflow: visible;
} .or-text {
background:white;
line-height: 0;
padding: 0 1em;
position: relative;
bottom: 0.75em;
} </style>
</head>
<body>
<script>
let map;
let view;
let pointLayer, lineLayer, polygonLayer;
require(["esri/Map",
"esri/views/MapView",
"esri/layers/FeatureLayer",
"dojo/domReady!"
function(Map,
MapView,
FeatureLayer,
Editor ) { // wfirehydrant
let wfirehydrantSymbol = {
type: "simple",
symbol: {
type: "picture-marker",
url: "https://img.icons8.com/doodle/48/000000/fire-hydrant--v1.png",
width: "20px",
height: "20px"
} let wfirehydrantPopup = {
"title": "wfirehydrant",
"content": "<br>FID:</br> {FID} <br>z:</br> {z}"
} // distrution pipe
let wdistributionpipeSymbol = {
type: "simple",
symbol: {
type: "simple-line",
cap: "round",
color: [0,172,230],
width: "5px",
style: "solid"
let wdistributionpipeLabel = {
symbol: {
type: "text",
color: "black",
haloColor: "white",
haloSize: "1.5px",
font: {
family: "Noto sans",
style: "italic",
weight: "normal"
labelPlacement: "above-center",
labelExpressionInfo: {
expression: "$feature.Shape__Length"
let wdistributionpipePopup = {
"title": "wdistributionpipe",
"content": "<br>Materal:</br> {MATERIAL_E} <br>CITYENAME:</br> {CITYENAME}"
} // transmission pipe
let wtransmissionPipeSymbol = {
type: "simple",
symbol: {
cap: "round",
color: [0, 0, 230],
width: "5px",
style: "solid"
let wtransmissionPipeLabel = {
symbol: {
type: "text",
color: "black",
haloColor: "white",
haloSize: "1.5px",
font: {
style: "italic",
weight: "normal"
let wtransmissionPipePopup = {
"title": "WTransmissionPipe",
const wtransmissionPipe = new FeatureLayer({
url: "https://services3.arcgis.com/0G16ZDbXMbWFq4Wr/arcgis/rest/services/wtransmissionpipe/FeatureServer/0",
outFiels: ["*"],
popupEnabled: true,
renderer: wtransmissionPipeSymbol,
labelingInfo: [wtransmissionPipeLabel],
popupTemplate: wtransmissionPipePopup
}); const wdistributionpipe = new FeatureLayer({
url: "https://services3.arcgis.com/0G16ZDbXMbWFq4Wr/arcgis/rest/services/wdistributionpipe/FeatureServer/0",
outFiels: ["*"],
popupEnabled: true,
renderer: wdistributionpipeSymbol,
labelingInfo: [wdistributionpipeLabel],
popupTemplate: wdistributionpipePopup
}) const wfirehydrant = new FeatureLayer({
url: "https://services3.arcgis.com/0G16ZDbXMbWFq4Wr/arcgis/rest/services/wfirehydrant/FeatureServer/0",
outFiels: ["*"],
popupEnabled: true,
renderer: wfirehydrantSymbol,
outFiels: ["FID", "Z"],
popupTemplate: wfirehydrantPopup
}) map = new Map({
basemap: "osm",
layers: [wtransmissionPipe, wdistributionpipe,
wfirehydrant
view = new MapView({
container: "viewview",
map: map,
center: [43.902257, 26.38444],
zoom: 15
}); view.map.allLayers.forEach((layer) => {
if (layer.type == 'feature') {
switch (layer.geometryType) { case "polyline":
lineLayer = layer;
break;
case "point":
pointLayer = layer;
break;
} }); const pointInfos = {
layer: pointLayer,
fieldConfig: [{
label: "Elevation"
label: "LONGITUDE"
}; const lineInfos = {
layer: lineLayer,
fieldConfig: [{
label: "Length"
label: "CITY NAME"
}; const editor = new Editor({
view: view, layerInfos: [{
layer: pointLayer,
fieldConfig: [pointInfos]
layer: lineLayer,
fieldConfig: [lineInfos]
}, ], snappingOptions: {
enabled: true,
selfEnabled: true,
featureEnabled: true,
featureSources: [{
layer: pointLayer
layer: lineLayer
}); view.ui.add(editor, "top-right"); }); </script> <div id="viewview"></div>
<div id="editDiv"></div>
</body></html>
here the screenshots
SaschaBrunnerCH
HI
You don't need to loop trough the layers. The Editor-Widget itself checks the editable layers and add them to the widget. If you would like to do some fine-grained configuration you need to that on: https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Editor.html#layerInfos
and even then you do not need to iterate because you define them separately and you can just use them.
To mention, your featurelayer are public accessible and everyone can edit them.
Working code-sample with your data:
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
  <meta name="description" content="">
  <title>Edting</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.20/esri/css/main.css">
  <style>
    html,
    body,
    #viewview {
      padding: 0px;
      margin: 0px;
      height: 100%;
      width: 100%;
  </style>
</head>
<body>
  <script>
    require(["esri/widgets/Editor", "esri/layers/FeatureLayer", "esri/views/MapView", "esri/Map"], function(Editor, FeatureLayer, MapView, Map) {
      const wfirehydrantSymbol = {
        type: "simple",
        symbol: {
          width: "20px",
          height: "20px"
      const wfirehydrantPopup = {
        title: "wfirehydrant",
        content: "<br>FID:</br> {FID} <br>z:</br> {z}"
      const wdistributionpipeSymbol = {
        type: "simple",
        symbol: {
          cap: "round",
          color: [0, 172, 230],
          width: "5px",
          style: "solid"
      const wdistributionpipeLabel = {
        symbol: {
          type: "text",
          color: "black",
          haloColor: "white",
          haloSize: "1.5px",
          font: {
            style: "italic",
            weight: "normal"
        title: "wdistributionpipe",
        content: "<br>Materal:</br> {MATERIAL_E} <br>CITYENAME:</br> {CITYENAME}"
        type: "simple",
        symbol: {
          cap: "round",
          color: [0, 0, 230],
          width: "5px",
          style: "solid"
        symbol: {
          type: "text",
          color: "black",
          haloColor: "white",
          haloSize: "1.5px",
          font: {
            style: "italic",
            weight: "normal"
        title: "WTransmissionPipe",
        popupEnabled: true,
        popupEnabled: true,
        popupEnabled: true,
      const map = new Map({
        basemap: "osm",
        layers: [wtransmissionPipe, wdistributionpipe, wfirehydrant]
      const view = new MapView({
        map: map,
        zoom: 15
        view: view,
        snappingOptions: {
          enabled: true,
          selfEnabled: true,
          featureSources: [{
              layer: wfirehydrant
              layer: wdistributionpipe
              layer: wtransmissionPipe
  </script>
</body>
</html>
SaschaBrunnerCH
HI
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewview {
      padding: 0px;
      margin: 0px;
      height: 100%;
      width: 100%;
  </style>
</head>
<body>
  <script>
        type: "simple",
        symbol: {
          width: "20px",
          height: "20px"
        type: "simple",
        symbol: {
          cap: "round",
          width: "5px",
          style: "solid"
        symbol: {
          type: "text",
          color: "black",
          haloColor: "white",
          haloSize: "1.5px",
          font: {
            style: "italic",
            weight: "normal"
        type: "simple",
        symbol: {
          cap: "round",
          color: [0, 0, 230],
          width: "5px",
          style: "solid"
        symbol: {
          type: "text",
          color: "black",
          haloColor: "white",
          haloSize: "1.5px",
          font: {
            style: "italic",
            weight: "normal"
        popupEnabled: true,
        popupEnabled: true,
        popupEnabled: true,
        basemap: "osm",
        map: map,
        zoom: 15
        view: view,
        snappingOptions: {
          enabled: true,
          selfEnabled: true,
          featureSources: [{
              layer: wfirehydrant
  </script>
</body>
</html>
AbirELTAIEF1
Really, Big Thank you
