Trying to create a chart based on average values in a column, tried usiing this script, where Z is the column that has my values, but the chart doesn't work, the values are also below zero but my chart axis seem to start from -1
function updateSceneLayer() { const query = sceneLayerView.createQuery(); query.geometry = sketchGeometry; query.distance = bufferSize; return sceneLayerView.queryObjectIds(query).then(highlightBuildings); } var depthChart = null; function queryStatistics() { const statDefinitions = [ { onStatisticField: "Z", outStatisticFieldName: "depth", statisticType: "avg" } ]; const query = sceneLayerView.createQuery(); query.geometry = sketchGeometry; query.distance = bufferSize; query.outStatistics = statDefinitions; return sceneLayerView.queryFeatures(query).then(function(result) { const allStats = result.features[0].attributes; updateChart(depthChart, [ allStats.depth ]); }, console.error); } // Updates the given chart with new data function updateChart(chart, dataValues) { chart.data.datasets[0].data = dataValues; chart.update(); } function createDepthChart() { const depthCanvas = document.getElementById("depth-chart"); yearChart = new Chart(depthCanvas.getContext("2d"), { type: "horizontalBar", data: { labels: [ "A1" ], datasets: [ { label: "Depth", backgroundColor: "#149dcf", stack: "Stack 0", data: [0] } ] }, options: { responsive: true, legend: { display: true }, title: { display: true, text: "xx" }, scales: { xAxes: [ { stacked: true, ticks: { beginAtZero: false, precision: 0 } } ], yAxes: [ { stacked: true } ] } } }); }
