Does the 4.x search widget require a view?
1133
08-29-2017 09:32 AM
MarcBate
Occasional Contributor II
I'd like to be able to use the search widget without a map. It seems to work, except the 'select-result' event never fires. Any ideas?
KellyHutchins
Esri Frequent Contributor
This is a bug in version 4.4 that will be addressed in version 4.5 of the API.
KellyHutchins
MarcBate
Is there also a bug where the search widget (which is associated with a view this time) but it is ignoring these properties when I set them to false?
var searchWidget = new Search({
  container: "searchWidget",
  view: view,
  resultGraphicEnabled: false,
  popupOpenOnSelect: false,
  popupEnabled: false
It is always showing the resulting graphic and a popup. As a workaround, I'm calling view.popup.close() and view.graphics.removeAll() in the 'select-result' event
KellyHutchins
Yes that also looks like an issue that is fixed for the next release (version 4.5)
RobertScheitlin__GISP
Marc,
   So you are attempting to use the search widget in your code and you do not have a view at all? When I added it to a sample that did have a view but the search widgets view was set to null I did not have any issue.
MarcBate
I want to essentially just geocode an address and get the XY coordinates for whatever the user selected. The widget displays without a view, but the 'select-result' event never fires. As a workaround, I'm just creating a basic view and hiding the DOM element
