Display attribute table with JavaScript API ver 4.9?
6171
10
10-21-2018 11:55 PM
lxd
How to display feature layer's attribute table with JavaScript API ver 4.9?
I am working with ArcGIS API for Javascript 4.9. I want to create a simple map view and display a table under it. I am stuck trying to work out how to display a table displaying data from a feature layer published on ArcGIS  with this version of API. I removed all code related to the map to make it simpler till I work out this table.
Here is my code:
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<title>Tutorial: Grids and Stores</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.9/esri/css/main.css">
</head>
<body class="claro">
<h1>Display table with feature layer and dgrid </h1>
<div id="grid"></div>
<script src="https://js.arcgis.com/4.9/"></script>
<script>
require([
"dojo/_base/declare",
"dstore/RequestMemory",
"dgrid/Grid",
"dgrid/extensions/Pagination"
], function (declare, RequestMemory, Grid, Pagination) {
// Create a Grid instance using Pagination, referencing the store
var gridFields = ["__OBJECTID", "WAL_NAME", "REGION", "WAL_ZONE", "REGION_WAL", // __OBJECTID
"WAL_Value", "SWAL_Value"
var grid = new (declare([ Grid, Pagination ]))({
collection: new RequestMemory({ target: "https://xxxxxxxxx/arcgis/rest/services/GCX/QFESAlertLevels_GCX/FeatureServer/1?f=pjson" }),
className: 'dgrid-autoheight',
columns: gridFields,
}, 'grid');
grid.startup();
</script>
</body>
</html>
The error that I get is:
Any ideas? Did anyone get it to work?
Thanks!
RobertScheitlin__GISP
Lidia,
  OK here is the sample re-worked to show all the data.
<!DOCTYPE html>
<html>
<head>
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>dGrid - 4.9</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      overflow: hidden;
    #info,
    #gridDisplay {
      position: absolute;
      bottom: 0;
      left: 0;
      height: 35%;
      background-color: white;
      border-color: grey;
      width: 100%;
      font-family: "Avenir Next W00", "Helvetica Neue", Helvetica, Arial, sans-serif;
      font-size: 14px;
    #info {
      z-index: 90;
      font-size: 16px;
      padding-left: 20px;
    #info * {
      padding-right: 20px;
    #gridDisplay {
      z-index: 80;
    .info {
      line-height: 20px;
      padding-left: 5px ! important;
    .dgrid-header,
    .dgrid-header-row {
      background-color: #eee;
      color: #57585A;
    .dgrid-row-even {
      background-color: #F7F8F8;
    .dgrid-row-odd {
      background-color: #EFEFEF;
    .dgrid-selected {
      background: #B4DAF5;
    .dgrid-row {
      border: none
  </style>
  <script>
    require([
        "esri/WebMap",
        "esri/views/MapView",
        "esri/layers/CSVLayer",
        "esri/Graphic",
        "esri/widgets/Legend",
        "esri/widgets/Expand",
        "esri/geometry/SpatialReference",
        "dgrid/OnDemandGrid",
        "dgrid/extensions/ColumnHider",
        "dojo/store/Memory",
        "dstore/legacy/StoreAdapter",
        "dgrid/Selection"
      function(
        WebMap, MapView, CSVLayer, Graphic, Legend, Expand, SpatialReference,
        OnDemandGrid, ColumnHider, Memory, StoreAdapter, Selection
        let map, view, csvLayer, csvLayerView, grid;
        const gridDiv = document.getElementById("grid");
        const infoDiv = document.getElementById("info");
        // create new map, view and csvlayer
        setupTheView();
        const gridFields = ["__OBJECTID", "Category", "Season", "Name",
          "Nature", "wmo_wind"
        // create a new datastore for the on demandgrid
        // will be used to display attributes of selected features
        const dataStore = new StoreAdapter({
          objectStore: new Memory({
            idProperty: "__OBJECTID"
        // create a grid with given columns once the csvlayer is loaded
        csvLayer.when(function() {
            // create a grid with columns specified in gridFields variable
            createGrid(csvLayer.fields);
            // get a reference the csvlayerview when it is ready. It will used to do
            // client side queries when user draws polygon to select features
            view.whenLayerView(csvLayer).then(function(layerView) {
              csvLayerView = layerView;
              popGrid();
          .catch(errorCallback);
         * Selects features from the csv layer that intersect
         * a polygon that user drew using sketch view model
        function popGrid() {
          view.graphics.removeAll();
          if (csvLayerView) {
            const query = {
              where: "1=1",
              outFields: ["*"]
            // query graphics from the csv layer view. Geometry set for the query
            // can be polygon for point features and only intersecting geometries are returned
            csvLayerView.queryFeatures(query).then(function(results) {
                const graphics = results.features;
                // if the grid div is displayed while query results does not
                // return graphics then hide the grid div and show the instructions div
                if (graphics.length > 0) {
                  gridDiv.style.zIndex = 90;
                  infoDiv.style.zIndex = 80;
                  document.getElementById("featureCount").innerHTML =
                    "<b>Showing attributes for " +
                    graphics.length.toString() + " features </b>"
                } else {
                  gridDiv.style.zIndex = 80;
                  infoDiv.style.zIndex = 90;
                // get the attributes to display in the grid
                const data = graphics.map(function(feature, i) {
                  return Object.keys(feature.attributes)
                    .filter(function(key) {
                      // get fields that exist in the grid
                      return (gridFields.indexOf(key) !== -1);
                    // need to create key value pairs from the feature
                    // attributes so that info can be displayed in the grid
                    .reduce(function(obj, key) {
                      obj[key] = feature.attributes[key];
                      return obj;
                // set the datastore for the grid using the
                // attributes we got for the query results
                dataStore.objectStore.data = data;
                grid.set("collection", dataStore);
         * fires when user clicks a row in the grid
         * get the corresponding graphic and select it
        function selectFeatureFromGrid(event) {
          // close view popup if it is open
          view.popup.close();
          // get the ObjectID value from the clicked row
          const row = event.rows[0]
          const id = row.data.__OBJECTID;
          // setup a query by specifying objectIds
          const query = {
            objectIds: [parseInt(id)],
            outFields: ["*"],
            returnGeometry: true,
            outSpatialReference: view.SpatialReference
          // query the csvLayerView using the query set above
              // remove all graphics to make sure no selected graphics
              view.goTo(graphics[0].geometry);
              // create a new selected graphic
              const selectedGraphic = new Graphic({
                geometry: graphics[0].geometry,
                symbol: {
                  type: "simple-marker",
                  style: "circle",
                  color: "orange",
                  size: "12px", // pixels
                  outline: { // autocasts as new SimpleLineSymbol()
                    color: [255, 255, 0],
                    width: 2 // points
              // add the selected graphic to the view
              // this graphic corresponds to the row that was clicked
              view.graphics.add(selectedGraphic);
         * Creates a new grid. Loops through poverty
         * csvLayer's fields and creates grid columns
         * Grid with selection and columnhider extensions
        function createGrid(fields) {
          var columns = fields.filter(function(field, i) {
            if (gridFields.indexOf(field.name) !== -1) {
              return field;
          }).map(function(field) {
            if (field.name === "__OBJECTID") {
              return {
                field: field.name,
                label: field.name,
                sortable: true,
                hidden: true
            } else {
              return {
                field: field.name,
                label: field.alias,
                sortable: true
          // create a new onDemandGrid with its selection and columnhider
          // extensions. Set the columns of the grid to display attributes
          // the hurricanes cvslayer
          grid = new(OnDemandGrid.createSubclass([Selection, ColumnHider]))({
            columns: columns
          }, "grid");
          // add a row-click listener on the grid. This will be used
          // to highlight the corresponding feature on the view
          grid.on("dgrid-select", selectFeatureFromGrid);
         * Sets up the view. WebMap with winkel III projection
         * basemap and hurricanes CsvLayer is added to the view.
        function setupTheView() {
          const url =
            "https://arcgis.github.io/arcgis-samples-javascript/sample-data/hurricanes.csv";
          csvLayer = new CSVLayer({
            title: "Hurricanes",
            url: url,
            spatialReference: new SpatialReference({wkid: 54042}),
            copyright: "NOAA",
            popupTemplate: {
              title: "{Name}",
              content: [{
                type: "text",
                text: "Category {Category} storm with that occurred at {ISO_time}."
                type: "fields",
                fieldInfos: [{
                  fieldName: "wmo_pres",
                  label: "Pressure"
                  fieldName: "wmo_wind",
                  label: "Wind Speed (mph)"
              fieldInfos: [{
                filedName: "ISO_time",
                format: {
                  dateFormat: "short-date-short-time"
            renderer: {
              type: "unique-value",
              field: "Category",
              uniqueValueInfos: createUniqueValueInfos()
          map = new WebMap({
            // contains a basemap with a Winkel III projection
            // the CSVLayer coordinates will re-project client-side
            portalItem: {
            layers: [csvLayer]
          view = new MapView({
            container: "viewDiv",
            map: map,
            highlightOptions: {
              color: "#2B65EC",
              fillOpacity: 0.4
            padding: {
              bottom: infoDiv.clientHeight
          const legendExpand = new Expand({
            view: view,
            content: new Legend({
              view: view,
              style: "card"
          view.ui.add(legendExpand, "top-left");
         * Used to create uniques values for the csvlayer renderer
        function createUniqueValueInfos() {
          const fireflyImages = [
            "cat1.png",
            "cat2.png",
            "cat3.png",
            "cat4.png",
            "cat5.png"
          const baseUrl =
            "https://arcgis.github.io/arcgis-samples-javascript/sample-data/";
          return fireflyImages.map(function(url, i) {
            return {
              value: i + 1, // Category number
              symbol: {
                type: "picture-marker",
                url: baseUrl + url
        function errorCallback(error) {
          console.log("error:", error)
  </script>
</head>
<body>
  <div id="viewDiv">
    <div id="info">
      <span class="info">
        <b>Populating grid...</b>
      </span>
      <br />
    </div>
    <div id="gridDisplay">
      <span class="info" id="featureCount"></span>
    </div>
  </div>
</body>
</html>
lxd
Hi Robert, yes, I looked into this example. They use selection to set data variable and I don't need to select anything in my case. I am not sure how to replace that bit of the example.
I have just copied parts of the code to show what I mean.
const graphics = results.features;......
const data = graphics.map(function(feature, i) {......
I need data variable to be all features in the dataset... Any ideas on how to achieve it?
Lidia,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      overflow: hidden;
    #info,
    #gridDisplay {
      position: absolute;
      bottom: 0;
      left: 0;
      height: 35%;
      border-color: grey;
      width: 100%;
      font-size: 14px;
    #info {
      z-index: 90;
      font-size: 16px;
      padding-left: 20px;
    #info * {
    #gridDisplay {
      z-index: 80;
    .info {
      line-height: 20px;
    .dgrid-header,
    .dgrid-header-row {
      color: #57585A;
    .dgrid-row-even {
    .dgrid-row-odd {
    .dgrid-selected {
    .dgrid-row {
      border: none
  </style>
  <script>
    require([
        "esri/WebMap",
        "esri/Graphic",
        "dgrid/Selection"
      function(
        setupTheView();
              popGrid();
          if (csvLayerView) {
            const query = {
              where: "1=1",
              outFields: ["*"]
                } else {
                      return obj;
          view.popup.close();
          const query = {
            outFields: ["*"],
                symbol: {
                  style: "circle",
                  color: "orange",
                    width: 2 // points
              return field;
              return {
                field: field.name,
                label: field.name,
                sortable: true,
                hidden: true
            } else {
              return {
                field: field.name,
                label: field.alias,
                sortable: true
            columns: columns
          }, "grid");
          const url =
            url: url,
            copyright: "NOAA",
            popupTemplate: {
              title: "{Name}",
              content: [{
                type: "text",
                type: "fields",
                fieldInfos: [{
                  label: "Pressure"
              fieldInfos: [{
                format: {
            renderer: {
              field: "Category",
          map = new WebMap({
            portalItem: {
            layers: [csvLayer]
            map: map,
            highlightOptions: {
              color: "#2B65EC",
              fillOpacity: 0.4
            padding: {
            view: view,
              view: view,
              style: "card"
            "cat1.png",
            "cat2.png",
            "cat3.png",
            "cat4.png",
            "cat5.png"
          const baseUrl =
            return {
              symbol: {
                url: baseUrl + url
  </script>
</head>
<body>
  <div id="viewDiv">
    <div id="info">
      <span class="info">
      </span>
      <br />
    </div>
    </div>
  </div>
</body>
</html>
lxd
Hi Robert,
Thank you. Great!
I have redone the code to use with my polygons and added ability to modify one field  by entering values and writing it back to the feature layer.
Glad it worked. Don’t forget to mark this question as answered by clicking the mark correct link on the reply that answered your question.
KarstenRank
Hi Robert,
I have added the links to the newest API 4.18 in the solution example:
  <link rel="stylesheet" href="https://js.arcgis.com/4.18/dgrid/css/dgrid.css"/>
  <link rel="stylesheet" href="https://js.arcgis.com/4.18/esri/css/main.css">
  <script src="https://js.arcgis.com/4.18/"></script>
The problem is, the grid is not filled? Do you know why?
Greetings
Karsten
Try dropping back to 4.17. I am having issues with grid in 4.18 too.
KarstenRank
The same result.
It looks like that it takes to  long for querying for the grid. If I inset a setTimeout the grid get filled:
              console.log("timeout start");
              setTimeout(function(){ popGrid(); }, 30000);
Karsten,
OK I see what the issue is. The popGrid is getting called before the view has an features in it and because the code is set to query the layer view there are no records to return to the grid. If you change the code to query the actual csv layer and not the layer view then you get the grid with all records of the layer.
          if (csvLayerView) {
            const query = {
              where: "1=1",
              outFields: ["*"]
//Changed to csvLayer instead of layer view
            csvLayer.queryFeatures(query).then(function(results) {
