Debugging TOC widget - Insert New Layer Prgrammaticaly
1056
09-11-2014 01:24 PM
AlexGole
Occasional Contributor II
Hi all,
I am trying to programmatically add layer to my map and TOC via the TOC widget.
However I am getting an error : "Cannot read property 'on' of undefined" when running the script. Not too sure what that means.
Anyway, my map is here. The idea is to click on a button and automatically add a layer to both TOC and map using bootstrap popover. As showed below
Any help is welcome!
Alex
KenBuja
MVP Esteemed Contributor
You're trying to add the "on" event to the TOC before it's defined.
map.on('layers-add-result', function (evt) {
    dynaLayer1.setVisibleLayers([1, 2, 4]);
    toc = new TOC({
        map: map,
        layerInfos: [{
            layer: dynaLayer1,
            title: "Layers",
            slider: true
    }, 'tocdiv');
    toc.startup();
toc.on('load', function () {
    if (console)
        console.log('TOC loaded');
    dom.byId("InsertNewLayer").disabled = false;
You'll have to move that inside the 'layers-add-result' event
    toc = new TOC({
        map: map,
        layerInfos: [{
            layer: dynaLayer1,
            title: "Layers",
            slider: true
    }, 'tocdiv');
    toc.startup();
        if (console)
KenBuja
    toc = new TOC({
        map: map,
        layerInfos: [{
            layer: dynaLayer1,
            title: "Layers",
            slider: true
    }, 'tocdiv');
    toc.startup();
    if (console)
    toc = new TOC({
        map: map,
        layerInfos: [{
            layer: dynaLayer1,
            title: "Layers",
            slider: true
    }, 'tocdiv');
    toc.startup();
        if (console)
AlexGole
That works better! Thanks. Now I still have the same type of error for dynaLayer2. Originally I had:
on(dom.byId("InsertNewLayer"), 'click', function (evt) {
                             if (dynaLayer2 != null) {
                                 map.removeLayer(dynaLayer2);
                                 toc.layerInfos.splice(1, 1);// remove it.
                                 dynaLayer2 = null;
                             dynaLayer2 = new ArcGISDynamicMapServiceLayer(dom.byId("NewLayerURL").value, {
                                 opacity: 0.8
                         //var h = map.on('layer-add-result', function(evt){
                         var h = dynaLayer2.on('load', function (evt) {
                             toc.layerInfos.splice(1, 0, {
                                 layer: dynaLayer2,
                                 title: "DynamicMapServiceLayer2",
                                 // collapsed: true, // whether this root layer should be collapsed initially, default false.
                                 slider: true, // whether to display a transparency slider.
                                 autoToggle: false //whether to automatically collapse when turned off, and expand when turn on for groups layers. default true.
                             toc.refresh();
                             h.remove();
Now, I have this:
                                 dynaLayer2 = null;
                                 opacity: 0.8
                                 layer: dynaLayer2,
                             toc.refresh();
                             h.remove();
Everything works fine except the button Add... in the popover (Add Layer) does not seem to be hooked correctly to the URL.
<!--Add Layer PopOver-->
        <div class="popover-markup" style="margin-top:-18px; margin-left:840px;">
            <a href="#" class="trigger" style="right: 250px; color: yellow;">Add Layer</a>
            <div class="head hide">Add layer</div>
            <div class="content hide">
                <div class="form-group">
                    <input type="text" class="form-control" placeholder="Enter Layer's URL here…">
                </div>
                <button id="InsertNewLayer" disabled="disabled" type="submit" class="btn btn-default btn-block">Add...</button>
            </div>
            <div class="footer hide">test</div>
        </div>
        <!--End PopOver-->
    </div>
Not so sure why yet. Am I missing something here?
Thank you for your help,
Alex
