DateTime Picker when editing (4.x)
905
06-13-2020 02:33 AM
RonParis
I have a js app that is utilising the editor widget for a number of feature layers. These feature layers have datetime fields, which need to be filled in by users. The default config for these fields when using the js app, is a free text field (image below).
My question is how do I make these date fields display as a DateTime Picker when editing?
Code sample:
view.map.layers.forEach(function(layer) {
if (layer.title === "Point Features") {
editConfigPointLayer = {
layer: layer,
// Set it so that only one field displays within the form
fieldConfig: [
label: 'Tier'
label: 'Delivery Phase'
label: 'Date Installed'
label: 'Proposed Implementation Date'
// Create the Editor
let editor = new Editor({
view: view,
// Pass in the configurations created above
layerInfos: [editConfigLinearLayer, editConfigPointLayer,editConfigPolygonLayer],
// Override the default template behavior of the Editor widget
supportingWidgetDefaults: {
featureTemplates: {
groupBy: customGroup
DateTime field - editing
Tags (3)
RobertHauck1
New Contributor II
Did you have any luck getting date / time pickers to work with the 4.x edit widget?
MKY
New Contributor III
DateTime picker is not working in 4.20 when editing. Any plans for 4.21?
DvirusG
Maybe 4.22, 4.23,4.24,4.25 ?!?
no... 😕
