I am using BaseMapGallery to give user the ability to customize map.
I have Two Questions :
Regards
Mohammed
This is not possible i think, i will look for a solution once i find it i will share it with the community.
Regards
Here is what I was referring to:
<!DOCTYPE HTML>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>BasemapGallery widget - 4.9</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.9/esri/css/main.css">
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
</style>
<script src="https://js.arcgis.com/4.9/"></script>
<script>
var sbasemap = '';
require([
"esri/Map",
"esri/views/SceneView",
"esri/widgets/BasemapGallery"
], function(
Map, SceneView, BasemapGallery
var map = new Map({
basemap: "gray"
var view = new SceneView({
container: "viewDiv",
map: map,
center: [139.68, 35.68],
zoom: 3
var basemapGallery = new BasemapGallery({
view: view
// Add the widget to the top-right corner of the view
view.ui.add(basemapGallery, {
position: "top-right"
map.watch('basemap', function(evt){
switch(evt.title){
case 'Streets':
sbasemap = 'streets';
break;
case 'Imagery':
sbasemap = 'satellite';
break;
case 'Imagery with Labels':
sbasemap = 'hybrid';
break;
case 'Topographic':
sbasemap = 'topo';
break;
case 'Light Gray Canvas':
sbasemap = 'gray';
break;
case 'Dark Gray Canvas':
sbasemap = 'dark-gray';
break;
case 'Oceans':
sbasemap = 'oceans';
break;
case 'National Geographic':
sbasemap = 'national-geographic';
break;
case 'Terrain with Labels':
sbasemap = 'terrain';
break;
case 'OpenStreetMap':
sbasemap = 'osm';
break;
default:
sbasemap = 'noStringConstant';
console.info(sbasemap);
</script>
</head>
<body>
<div id="viewDiv"></div>
</body>
</html>
Since my application is multilingual, it would be harder to hold up all the names.
Thanks for your answer.
Regards
In that case just use the portalItem Id:
//console.info(evt.portalItem.id);
switch(evt.portalItem.id){
case 'd8855ee4d3d74413babfb0f41203b168':
break;
case '86de95d4e0244cba80f0fa2c9403a7b2':
break;
case '413fd05bbd7342f5991d5ec96f4f8b18':
break;
case '6e03e8c26aad4b9c92a87c1063ddb0e3':
sbasemap = 'topo';
break;
case '8b3b470883a744aeb60e5fff0a319ce7':
sbasemap = 'gray';
break;
case '25869b8718c0419db87dad07de5b02d8':
break;
case '48b8cec7ebf04b5fbdcaf70d09daff21':
break;
case '509e2d6b034246d692a461724ae2d62c':
break;
case 'aab054ab883c4a4094c72e949566ad40':
break;
case '5d2bfa736f8448b3a1708e1f6be23eed':
sbasemap = 'osm';
break;
default:
Thank You, it works !
