Custom Print Widget
1588
12-07-2021 06:52 PM
Wade
New Contributor III
This example
https://developers.arcgis.com/javascript/latest/sample-code/widgets-print/
In the layer, some layers are hidden in the list,
When Output PDF still display,
Can control the legend Individual display?
Noah-Sager
Hi @Wade, are you talking about hidden layers displaying in the printed legend? If so, this is a known issue that was recently fixed. You can see the fix now using next, or wait for 4.22 to release (which should be later this week).
next: https://github.com/Esri/feedback-js-api-next
Kishore
@Wade  By default Print widget in JS API honors only the visible layers.  I tested the sample and it is working fine. please check the screenshots Sandbox app with displaying he legends:
 and the print generated from the app:
 If you can provide more details on the requirements we can check.
Regards,
Kishore
Wade
New Contributor III
Hi @Kishore
The question is, There are two layer inside, One does not display in the list,
When Output PDF still display, Can control the legend Individual display?
<html>
<head>
    <meta charset="utf-8" />
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
    <title>Print widget | Sample | ArcGIS API for JavaScript 4.21</title>
    <link rel="stylesheet" href="https://js.arcgis.com/4.21/esri/themes/light/main.css" />
    <style>
        html,
        body,
        #viewDiv {
            padding: 0;
            margin: 0;
            height: 100%;
            width: 100%;
            overflow: hidden;
        .esri-zoom {
            display: none;
    </style>
    <script src="https://js.arcgis.com/4.21/"></script>
    <script>
        require([
            "esri/views/MapView",
            "esri/Map",
            "esri/layers/FeatureLayer",
            "esri/layers/MapImageLayer",
            "esri/widgets/LayerList",
            "esri/widgets/Print",
            MapView,
            Map,
            FeatureLayer,
            MapImageLayer,
            LayerList,
            Print
            const map = new Map({
                basemap: "topo-vector"
            const view = new MapView({
                container: "viewDiv",
                map: map,
                extent: {
                    xmin: -9177811,
                    ymin: 4247000,
                    xmax: -9176791,
                    ymax: 4247784,
                    spatialReference: 102100
            const featureLayer = new FeatureLayer({
                url: "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Landscape_Trees/FeatureServer/0",
                listMode: "hide"
            const mapImageLayer = new MapImageLayer({
                url: "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer"
            map.add(featureLayer);
            map.add(mapImageLayer);
            view.when(() => {
                const print = new Print({
                    view: view,
                    printServiceUrl:
                        "https://utility.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task"
                const layerList = new LayerList({
                    view: view
                view.ui.add(print, "top-right");
                view.ui.add(layerList, "top-left");
    </script>
</head>
<body class="calcite">
    <div id="viewDiv"></div>
</body>
</html>
Noah-Sager
Wade
New Contributor III
Hi @Noah-Sager
Thank you for providing information.
Noah-Sager
@Wade, quite welcome. Feel free to mark my post as the solution if you feel it answered your question.
