Custom Print Template?
2976
03-07-2013 09:17 AM
AlexGilvarry
New Contributor II
Is it possible to specify a custom print template when you're using the print widjit? I'd like to be able to add a custom logo and change the template color on the pdf's my map "prints." Currently it's just a stock white template like in the example here.
Thanks for any help!
JasonJaworski
New Contributor II
Has anyone found a way to do this? I have a request to make the footer text larger and center it on the map, rather than right aligned, but I have not found one example of this anywhere. Footer is always small text and on lower right.
Can anyone help?
thejuskambi
Occasional Contributor III
In ArcGIS Server you can create your own print service with the custom templates. You will find more details here Tutorial: Publishing additional services for printing—Documentation (10.3 and 10.3.1) | ArcGIS for S... and then you can use the print dijit with it.
MichaelVolz
Esteemed Contributor
Did you create your own custom print service with your customized print templates?
ChrisSmith7
This came-up on another thread (in short, you can create custom templates):
Printing
JasonJaworski
New Contributor II
I did not create my own custom print service. Thank you for the tips. I will read up on this and go that route. Thank you!
