Has anyone found a way to do this? I have a request to make the footer text larger and center it on the map, rather than right aligned, but I have not found one example of this anywhere. Footer is always small text and on lower right.
Can anyone help?
In ArcGIS Server you can create your own print service with the custom templates. You will find more details here Tutorial: Publishing additional services for printing—Documentation (10.3 and 10.3.1) | ArcGIS for S... and then you can use the print dijit with it.
Did you create your own custom print service with your customized print templates?
This came-up on another thread (in short, you can create custom templates):
I did not create my own custom print service. Thank you for the tips. I will read up on this and go that route. Thank you!
