Hello,
I am very new to ArcGIS. I have a web page that contains an embedded map of an area that contains several regions. I would like to create onmouseover and onclick events for the regions on the map.
onmouseover: region polygon becomes visible.
onclick: a new tab opens linked to an information page and gallery of the region.
I have worked with SVG on other sites where the path is wrapped in an anchor tag and CSS controls path colour. Example:
CSS: .region-svg:hover { fill: #003366; }
HTML:
<a href="www.somepage.com">
<svg width="400" height="110">
<rect class="region-svg" width="300" height="100" style="fill:#006600;stroke-width:3;stroke:rgb(0,0,0)" />
</svg>
</a>
So how to attain a similar effect with an embedded ArcGIS map? The map is served from a portal and I can edit all sort of attributes, and popups, but I do not want the popup, I want it to highlight the region on mouse over, and on click go to a specific url for each region. Is there a way to do this with ArcGIS?
Thank you.
Solved! Go to Solution.
Check out the hitTest() method of MapView. I think you can use it to do what you need. Here's a sample app with pointer-move event.
