Create spheres at right location under the surface
512
05-30-2019 02:52 PM
AdamThompson3
New Contributor III
Hello,
I have been trying to build something very similar to this WebMap https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=scene-local  using my own data, I have gotten most of it to work for myself except extruding my points to the right location.. Here is what my code is producing;
The points are sort of half n half on the surface and below, where I would like them to be displayed is right at the bottom of the well.I cant use a general offset because all the bottom of the wells are different depths, if there is a way I could offset the points by grabbing the value in that depth column that would work, but I am still new to this JavaScript API. I have pretty much used the same code as the one in that scene just with different parameters. here is the code;
Thank you for any help!
SaschaBrunnerCH
Hi Adam
Do your data have z-values?
If not you can set the elevation with an Arcade Expression see the help FeatureLayer-elevationInfo. Or see in the chapter "Feature Z" in arcade guide.
With the following codesnippet you can see the 3d-points below the ground with -1000 meters:
          elevationInfo: {
            mode: "relative-to-ground",
            featureExpressionInfo: {
              expression: "-1000"
full sample:
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
    <title>Create a local scene - 4.11</title>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
      #homeDiv {
        left: 15px;
        top: 130px;
        z-index: 35;
        position: absolute;
    </style>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.11/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.11/"></script>
    <script>
      require([
        "esri/Map",
        "esri/views/SceneView",
        "esri/layers/FeatureLayer",
        "esri/widgets/Home"
      ], function(Map, SceneView, FeatureLayer, Home) {
        var quakesUrl =
          "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/ks_earthquakes_since_2000/FeatureServer/0";
        // The clipping extent for the scene
        var kansasExtent = {
          // autocasts as new Extent()
          xmax: -10834217,
          xmin: -10932882,
          ymax: 4493918,
          ymin: 4432667,
          spatialReference: {
            // autocasts as new SpatialReference()
            wkid: 3857
        var quakesRenderer = {
          type: "simple", // autocasts as new SimpleRenderer()
          symbol: {
            type: "point-3d", // autocasts as new PointSymbol3D()
            symbolLayers: [
                type: "object", // autocasts as new ObjectSymbol3DLayer()
                resource: {
                  primitive: "sphere"
          visualVariables: [
              type: "size",
              field: "mag",
              axis: "all",
              stops: [
                  value: 2,
                  value: 5,
        // Defines a layer for drawing the exact location of quakes below the surface
        var quakesDepthLayer = new FeatureLayer({
          url: quakesUrl,
          // Show only quakes of magnitude 2.0 or higher
          definitionExpression: "mag >= 2",
          outFields: ["*"],
          renderer: quakesRenderer,
          returnZ: false,
          elevationInfo: {
              expression: "-1000"
        var map = new Map({
          basemap: "topo",
          layers: [
            quakesDepthLayer
          ground: {
            navigationConstraint: {
              type: "none"
        var view = new SceneView({
          container: "viewDiv",
          map: map,
          // Indicates to create a local scene
          viewingMode: "local",
          // Use the exent defined in clippingArea to define the bounds of the scene
          clippingArea: kansasExtent,
          extent: kansasExtent,
          // Turns off atmosphere and stars settings
          environment: {
            atmosphere: null,
            starsEnabled: false
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
SaschaBrunnerCH
Hi Adam
          elevationInfo: {
              expression: "-1000"
full sample:
<!DOCTYPE html>
<html>
  <head>
    <meta
      name="viewport"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
      #homeDiv {
        left: 15px;
        top: 130px;
        z-index: 35;
        position: absolute;
    </style>
    <link
      rel="stylesheet"
    <script>
      require([
        "esri/Map",
        "esri/widgets/Home"
        var quakesUrl =
          xmax: -10834217,
          xmin: -10932882,
          ymax: 4493918,
          ymin: 4432667,
          spatialReference: {
            wkid: 3857
          symbol: {
            symbolLayers: [
                resource: {
                  primitive: "sphere"
          visualVariables: [
              type: "size",
              field: "mag",
              axis: "all",
              stops: [
                  value: 2,
                  value: 5,
          url: quakesUrl,
          outFields: ["*"],
          returnZ: false,
          elevationInfo: {
              expression: "-1000"
        var map = new Map({
          basemap: "topo",
          layers: [
            quakesDepthLayer
          ground: {
              type: "none"
          map: map,
          environment: {
            atmosphere: null,
            starsEnabled: false
    </script>
  </head>
  <body>
  </body>
</html>
AdamThompson3
New Contributor III
Hey Sascha,
Thanks for the reply! That was exactly it with the "HasZ" property on my shapefile, bit of a silly mistake but when I displayed the points through arcmap in "Add XY Data" I had forget to include that z field, all is working well now
I just have a problem with authorization now, I have created a thread for this also https://community.esri.com/thread/234792-authentication-of-agol-layers-from-webmap
should you have the time to take a look into the issue that would be greatly appreciated!
Thank you
