coordinateFormatter fail when use DMS
1230
04-19-2021 07:26 AM
geopamplona
New Contributor III
I using "coordinateFormatter" to translate string coordinates to point.
When try convert coordinates to point i get null. Syntax of coordinates seem correct.
I using:
  require([
	"esri/geometry/coordinateFormatter"
  ], function(coordinateFormatter
	coordinateFormatter.load().then(function() {
	  var point = coordinateFormatter.fromLatitudeLongitude("55°56′39″N 3°09′43″W");
	  console.log(point)
Tags (1)
UndralBatsukh
Hi there,
The fix for this issue will be included at version 4.20 which will be released late June, 2021.
You can test the fix on our `next` version. Here is a test app that shows the new supported characters for CoordinateFormatter.fromLatitudeLongitude: https://codepen.io/U_B_U/pen/XWMdPPZ
-Undral
UndralBatsukh
Hi there,
Thanks for reporting this issue. We have created an issue for this and I will be sure to update you once we address it. In meantime, you can replace degree character/° to * as shown below:  This should work.
`55*56'39"N 3*09'43"W`
-Undral
UndralBatsukh
Hi there,
-Undral
geopamplona
New Contributor III
Thanks !
