when I use standard AMD loader for modules, code assist is not working:
/// <reference path="typings/arcgis-js-api/arcgis-js-api.d.ts"/> require(["esri/map", "esri/layers/FeatureLayer", "dojo/domReady!"], function(Map, FeatureLayer) { var map = new Map("map", { center: [-118, 34.5], zoom: 8, basemap: "topo" }); });
But when I switch require to define like that, code assist starts working, but script throws exception "Error: multipleDefine"
/// <reference path="typings/arcgis-js-api/arcgis-js-api.d.ts"/> define(["esri/map", "esri/layers/FeatureLayer", "dojo/domReady!"], function(Map, FeatureLayer) { var map = new Map("map", { center: [-118, 34.5], zoom: 8, basemap: "topo" }); });
Any idea to work around this problem?
