Cluster for graphic layer Arcgis Javascript 3.x
1925
6
09-10-2019 08:07 AM
ADITYAKUMAR1
Occasional Contributor III
I have a graphic layer.
I want to cluster this data and display cluster on map(Arcgis JavaScript 3.x)
Any idea?
BenElan
ADITYAKUMAR1
Hi Ben,
clusterLayer = new ClusterLayer({
              "data": photoInfo.data,
              "distance": 100,
              "id": "clusters",
              "labelColor": "#fff",
              "labelOffset": 10,
              "resolution": map.extent.getWidth() / map.width,
              "singleColor": "#888",
              "singleTemplate": popupTemplate
In my case what will be the data?
Thanks
Kumar
BenElan
This is how I would turn on clustering
var layer = new FeatureLayer(serviceUrl, {
      featureReduction: {
        type: "cluster"
Here is a simple sample to demonstrate the code above
VictorTey
Hi ADITYA KUMAR‌, the data will be
photoInfo.data = arrayUtils.map(resp, function(p) {
var latlng = new  Point(parseFloat(p.lng), parseFloat(p.lat), wgs);
var webMercator = webMercatorUtils.geographicToWebMercator(latlng);
var attributes = {
"Caption": p.caption,
"Name": p.full_name,
"Image": p.image,
"Link": p.link
return {
"x": webMercator.x,
"y": webMercator.y,
"attributes": attributes
so basically an array with the following structure.
"x": 120,
"y": -32,
"attributes": {
                     "Caption": "caption",
"Name": "a name",
"Image": small.jpg,
"Link": "http link"
CRSC
New Contributor II
Hi Adithya, Can you pls tell me which module have you imported for ClusterLayer? Currently i'm using 4.20 JS API version.
RaviVadlamani
Is it possible to add clustering to graphics layer in version 4.27 ?
featureReduction props is not available in the docs also.
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-GraphicsLayer.html#propert...
Is it possible to have clustering if it has only points geometry in graphics layer ? i know Polygon and Line string is not supported
