Closest Facility with Feature Layer from ArcGIS Online
1041
05-07-2021 08:49 AM
JohnPaulAlbana
I am trying to use a feature layer from ArcGIS Online to be an input facility in my closest facility parameter. I just recently started using ArcGIS JavaScript API and I saw someone's example in this forum which looks similar to this:
            facilitiesFeatureLayer = new FeatureLayer(
                    mode:FeatureLayer.MODE_SNAPSHOT
            let featuresetFacilities = new FeatureSet({
            featuresetFacilities.features = facilitiesFeatureLayer.graphics;
            function findClosestFacility(startFeaturefacilityFeatures) {
                const closestFacilityTask = new ClosestFacilityTask({
                const params = new ClosestFacilityParameters({
                    incidents: new FeatureSet({
                        features: [startFeature],
                    returnRoutes: true,
                    returnFacilities: true,
                    defaultTargetFacilityCount: 3,
                params.facilities = featuresetFacilities;
The code runs but returns no results:
HEJHh
JohnGrayson
In your codepen you are mixing 3.x and 4.x code; that won't work.  Here's a slightly modified version of your code that gets and sets the facilities before you start trying to call the solver:
https://codepen.io/john-grayson/pen/oNZgPYX
Noah-Sager
 Hi @JohnPaulAlbana, can you post a link to an app that reproduces this issue? On something like Codepen would be great. You can omit the apiKey if you are using one. Then I can investigate further.
JohnPaulAlbana
Hi @Noah-Sager , thanks for coming by, here is the codepen link:
Noah-Sager
The first error you see when loading the app is: Uncaught (in promise) ReferenceError: facilities is not defined
So we need to get the locations of the features into a facilities variable. There is some good doc to go through here: https://developers.arcgis.com/documentation/mapping-apis-and-services/routing/closest-facility-routi...
I can take a closer look next week as well.
JohnGrayson
