In arcgis pro, the feature layer is ordered correctly on the map (e.g. if I click on overlapped objects, the object with a highest value appears first (in this case year), such that 2017 is above 2016, 2016 above 2015, etc), but when drawn as a web layer, the same data has random order (2016, 2015, 2017... ) -- is there a method of forcing the correct order (e.g. via the infotemplate)?
