Change widget direction (horizontal/vertical) within regions
2097
08-02-2019 12:25 PM
DavidSchontzler
New Contributor III
I am adding widgets to my view like so:
view.add(widget1, "top-left");
view.add(widget2, "bottom-right");‍‍
I noticed that the widgets on the top regions are stacked vertically and the widgets in the bottom regions are laid out horizontally. You can see a sample here: https://codepen.io/dschontz/pen/zgErxO
Questions:
  1. Can you set the flow of widgets on a per-region basis? For example, can I have the bottom-right region stack widgets vertically?
  2. Can I have a region flow in both directions? For example, a couple widgets horizontally placed in the bottom-right corner, and another 2 widgets placed vertically above them so that they form a kind of "corner" on the map _|.
Tags (1)
Noah-Sager
Hi David, great questions. The current behavior you are experiencing is the default behavior, and is by design. We are considering making this a configurable property at a later release.
For now, you can place additional widgets manually using css.
doc
https://developers.arcgis.com/javascript/latest/api-reference/esri-views-ui-UI.html#add
sample in action (using the "manual" position)
https://developers.arcgis.com/javascript/latest/sample-code/timeslider-filter/index.html
YirenWangDesigner
Hi Noah or whom that may concern -
I have a similar need and wonder if there's an update about this configuration after 4 years? That users can stack widgets added vertically at bottom-right; OR similarly, widgets at top-left with a horizontal layout.
Thanks in advance.
