Change visibility of layer at a particular map scale.
1019
08-09-2019 08:05 AM
ADITYAKUMAR1
Occasional Contributor III
  I am changing the map extent and I want at a particular map scale the layer visibility should be turned off.
if (level > 0) {
topic.subscribe("LayerInfos/ExtentChange", lang.hitch(this, function (cur, evt, vs) {
var scale = evt.lod.scale;
if (layerInfo.initVisibaleAtScale == true) {
console.log(layerInfo.title);
As of now I am just able to check if its visible at a scale. Instead I want to set the visibility off.(3.x)
Thanks
Kumar
ADITYAKUMAR1
I was able to resolve it by this.map.selectablelayer[2].visible = false;
Thanks for all the support.
RobertScheitlin__GISP
Kumar,
   It would look something like this:
if(scale >= x) {
  map.getLayer(layerInfo.id).hide();
ADITYAKUMAR1
Hi Robert,
  But I dont have any hide() option available.
ADITYAKUMAR1
