Hi, I'm trying to change the transparency of a layer in a map service. I have looked at examples and have tried different things but nothing seems to change the transparency. What am I missing?
map = new Map("map", {
basemap: "streets",
center: [-117.42330, 47.751103],
zoom: 11
var roadLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://gisappserv3/ArcGIS/rest/services/SCOUT/ENGINEERINGqueries/MapServer",
visible: true
roadLayer.setVisibleLayers([28]);
map.addLayers([roadLayer]);
var optionsArray = [];
var drawingOptions = new LayerDrawingOptions();
drawingOptions.transparency = 50;
optionsArray[28] = drawingOptions;
map.roadLayer.setLayerDrawingOptions(optionsArray);
To be able to change the layer transparency at runtime. The map service should be enabled for Dynamic service. Please check the same.
Hi John,
Make sure that the server you pointing to in your snippet http://gisappserv3/ArcGIS/rest/services/SCOUT/ENGINEERINGqueries/MapServer
is turn on Supports Dynamic Layers to true
You might already saw this sample: Change attribute used for a renderer | ArcGIS API for JavaScript check their server that used has already turn on the Dynmaic Layer: Census (MapServer)
Here is the reference about how to Enabling dynamic layers on a map service in ArcGIS for Desktop—Help | ArcGIS for Desktop
Hope this can help!
I've been using setOpacity and I've used this on both dynamic map services as well as feature layers.
I have a dojo horizontal slider defined as:
<div id="parcelOpacity" data-dojo-type="dijit/form/HorizontalSlider" data-dojo-props="showButtons:'true', value:1, minimum:0, maximum:1"> Parcel Transparency </div>
I have a listener associated with it:
on(registry.byId('parcelOpacity'), 'change', changeOpacity);
This is the function:
function changeOpacity(op) { status_stateOwnParcelLayer.setOpacity(op);//this is an ArcGISDynamicMapServiceLayer stateOwnFeatureLayer.setOpacity(op);//this is a featureLayer }
