Change MapView scale on mobile device in CSS?
699
11-13-2018 02:33 PM
JaredPilbeam2
MVP Regular Contributor
I can't seem to find the element to change the scale. Can it be done in the CSS? I've tried this:
    @media (max-width: 480px) {
        view MapView {
            scale: 1300000,
RobertScheitlin__GISP
Jared,
   You can not do MANY things in css. This will have to be done in JS code.
Jared,
JaredPilbeam2
I guess what I was asking was whether it's possible to have two different scales, one for the PC and one for the phone.
Yes, it is just not something that can be done in css. It has to be done in JS code.
JaredPilbeam2
Robert,
Thanks for directing me away from the CSS. Whereas before I created a Map instance, I now created a WebMap. And this seems to have answered my question.
       * Creates a new WebMap instance. A WebMap must reference
       * a PortalItem ID that represents a WebMap saved to
       * arcgis.com or an on-premise portal.
       * To load a WebMap from an on-premise portal, set the portal
       * url with esriConfig.portalUrl.
        var webmap = new WebMap({
         portalItem: {
       * Set the WebMap instance to the map property in a MapView.
        var view = new MapView({
          map: webmap,
          container: "viewDiv",
I had a lot of help from these two examples:
Load a basic WebMap | ArcGIS API for JavaScript 4.9
Swap web maps in the same view | ArcGIS API for JavaScript 4.9
