Change Feature Layer Symbol on Hover Event
4001
6
06-19-2019 12:59 PM
ParkerWelch
New Contributor III
BACKGROUND
I am not a web developer. I am sure I violate all sorts of best practices and code conventions. Feel free to suggest code optimizations if you're so inclined.
I am trying to simply add a building 'highlight' and change the cursor to pointer on hover. I don't want to change the fill inside the building like in the example below. I just want to add a highlight outline.
QUESTIONS
  1. Any idea what may be causing my feature layer to 're-render' on hover?
    • all other features in the layer turn off then on again during the unique value renderer change that is triggered by the hover event
    •  I'm hoping to avoid the 'blinking' effect. Just want to change the unique value renderer on the building that was hovered over without adjusting the rest of the layer symbology
    • something like, "if hittest returns an item in the buildings layer, add a graphic on top of the existing layer with custom symbology without reloading the entire layer"
  2. How can I get the cursor to change to the pointer on the polygon fill as well? Currently, the arrow only changes to pointer when it is over the building outline.
    • This might be due to my custom symbology
CONSIDERATIONS
  • I have many layers in this map. The filter method on line 43 wasn't working, so I made a conditional on line 41 to only return hits from my buildings_lyr. I am sure this can be optimized if you have suggestions
CODE
This code was taken from this thread and adapted to my particular use.
It's possible that I unknowingly removed bits of the code that is causing the weird functionality.
Please pardon the indentation errors, this is just how it pastes into the syntax highlighter.
function changeCursor(response){
        if (response.results.length > 0){
          document.getElementById("viewDiv").style.cursor = "pointer";
        } else {
          document.getElementById("viewDiv").style.cursor = "default";
  	function getGraphics(response) {
  		// the topmost graphic from the click location
  		// and display select attribute values from the
  		// graphic to the user
  		var graphic = response.results[0].graphic;
  		var attributes = graphic.attributes;
  		var name = attributes.BUILDINGNAME;
  		dom.byId("info").style.visibility = "visible";
  		dom.byId("name").innerHTML = name;
  		// symbolize all line segments with the given
  		// storm name with the same symbol
  		var renderer = new UniqueValueRenderer({
  			field: "BUILDINGNAME",
  			defaultSymbol: buildings_lyr.renderer.symbol || buildings_lyr.renderer.defaultSymbol,
  			uniqueValueInfos: [{
  				value: name,
  				symbol: new SimpleFillSymbol({
  					color:blue,
						outline: {
							color: orange,
							width: 1
  		buildings_lyr.renderer = renderer;
  	view.on("pointer-move", function (evt) {
  		var screenPoint = {
  			x: evt.x,
  			y: evt.y
  		// the hitTest() checks to see if any graphics in the view
  		// intersect the given screen x, y coordinates
  		view.hitTest(screenPoint)
  			.then(function (response) {
  				if (response.results.length > 0) {
  					if (response.results[0].graphic.layer.title == 'buildings_app') {
  						const graphic = response.results.filter(function (result) {
  							return result.graphic.layer === buildings_lyr;
  						changeCursor(response);
  						//getGraphics(response); //!!Uncomment this when getGraphics is fixed
  				} else {
		buildings_lyr.then(function() {
			var renderer = buildings_lyr.renderer.clone();
			renderer.symbol.color = [255,255,255,1.0];
RobertScheitlin__GISP
Parker,
  OK, this is what you are after then (full working sample, no flicker):
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <meta name="description" content="[Highlight features with hover events - 4.11]">
  ArcGIS API for JavaScript, https://js.arcgis.com
  For more information about the view-hittest sample, read the original sample description at developers.arcgis.com.
  https://developers.arcgis.com/javascript/latest/view-hittest/index.html
  <title>Highlight features with hover events - 4.11</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.11/esri/css/main.css">
  <link rel="stylesheet" href="https://js.arcgis.com/4.11/dijit/themes/claro/claro.css">
  <script src="https://js.arcgis.com/4.11/"></script>
  <script>
    var dialog, dRenderer;
    require([
      "esri/core/watchUtils",
      "esri/Map",
      "esri/views/MapView",
      "esri/layers/FeatureLayer",
      "esri/renderers/UniqueValueRenderer",
      "esri/symbols/SimpleLineSymbol",
      "dojo/dom",
      "dojo/dom-style",
      "dijit/popup",
      "dojo/domReady!"
    ], function (
      watchUtils,
      Map,
      MapView,
      FeatureLayer,
      UniqueValueRenderer,
      SimpleLineSymbol,
      dom,
      domStyle,
      dijitPopup
      var layer = new FeatureLayer({
        url: "https://services.arcgis.com/8Pc9XBTAsYuxx9Ny/arcgis/rest/services/BuildingFootprint2D_gdb/FeatureServer/0",
        outFields: ["*"]
      var map = new Map({
        basemap: "dark-gray",
        layers: [layer]
      var view = new MapView({
        container: "viewDiv",
        map: map,
        center: [-80.135073, 25.774479],
        zoom: 16
      function changeCursor(response) {
        } else {
        view.graphics.removeAll();
          graphic.symbol = {
            type: "simple-fill",
            style: "none",
            outline: { // autocasts as new SimpleLineSymbol()
              color: "orange",
              width: 1
          view.graphics.add(graphic);
      view.when(function () {
        view.whenLayerView(layer).then(function (lview) {
          watchUtils.whenFalseOnce(lview, "updating", function () {
            // Set up a click event handler and retrieve the screen x, y coordinates
              var screenPoint = {
                x: evt.x,
                y: evt.y
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
Parker,
   I am missing the part in your posted code where you are changing the layers renderer... I see you have getGraphics commented out so the only thing that is happening on mouse over is the cursor change. Maybe this is not the right code you pasted?
ParkerWelch
New Contributor III
Sorry for the confusion Robert. I tried to address an issue between SimpleLine vs SimpleFill and pasted a branched version of my code which I haven't been able to get working. The code pasted below resulted in the behavior present in the original GIF.
However, I am still uncertain what you mean by the "the part in your posted code where you are changing the layers renderer". I thought that was happening on line 34?
        } else {
  				value: name,
  				symbol: new SimpleLineSymbol({
  					color: "orange",
  					width: 1,
  					cap: "round"
  		var screenPoint = {
  			x: evt.x,
  			y: evt.y
  				} else {
Parker,
  The symbol would change at line 34 if you did not comment out the getGraphics line in your previous code.
  } else {
      value: name,
      symbol: {
        type: "simple-fill",  // autocasts as new SimpleFillSymbol()
        color: [ 51, 51, 204, 0.9 ],
        style: "solid",
          color: "orange",
          width: 1
  var screenPoint = {
    x: evt.x,
    y: evt.y
      if (response.results.length > 0 && response.results[0].graphic.layer.title == 'buildings_app') {
      } else {
ParkerWelch
New Contributor III
Thanks Robert - the commenting out of the getGraphics() function was a mistake. I understand that if it's commented out, it will not fire. I have adjusted the code accordingly.
Re: your previous comment, I tested the code you supplied and created a GIF of the behavior below. I have a few issues with how it's performing...
  • Notice the 'flicker' of the buildings layer upon hover. Is there a way to make it smoother so it doesn't flash off/on? Is the layer having to render again? If so, might the flicker be caused by the size of the feature service?
  • Also, notice that the changed buildings renderer remains until a new building is hovered over.
    • Really, I'm only trying to indicate to the user with some minor visual feedback that they can click a building to get a pop-up. The change in rendering is not meant to persist throughout the session. it should be 'reset' upon the pointer leaving the building outline
  • Also, notice that the cursor remains as the pointer even after it has left the building outline. How can I adjust the script to change back to the arrow upon leaving the building?
Parker,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
      "esri/Map",
      "dojo/dom",
      "dojo/dom-style",
      "dijit/popup",
      "dojo/domReady!"
    ], function (
      watchUtils,
      Map,
      MapView,
      FeatureLayer,
      SimpleLineSymbol,
      dom,
      domStyle,
      dijitPopup
        outFields: ["*"]
      var map = new Map({
        layers: [layer]
        map: map,
        zoom: 16
        } else {
          graphic.symbol = {
            style: "none",
              color: "orange",
              width: 1
              var screenPoint = {
                x: evt.x,
                y: evt.y
  </script>
</head>
<body>
</body>
</html>
ParkerWelch
New Contributor III
Many thanks Robert. I really appreciate your help. I'll take a look later today at adapting that working sample into my app.
