Capture User x/y Mouse Click Widget and URL Link
1818
15
02-08-2019 08:50 AM
joerodmey
Hi all,
Right now in WAB I have code to allow the user to click on the map, capture the x/y location, initate a popup with a link (that has the x/y location passed in), and when the link is hit fires up Survey123 to enter data.
What I want to do next is allow the user to click a button to perform this rather than have this option on "all the time".
Any ideas or samples?
Joe
RobertScheitlin__GISP
Joe,
   So you start by getting the basic widgets template from the samples folder and adding your code to that (removing all the fluff that you will not need). I have done all that for you in the attached file. The widget is what you are after I think or it is almost complete.
Joe,
  Please provide your full code you have right now and I will help you convert this to a widget.
joerodmey
Hi Robert,
I have included my MapManager.js
define([
  'dojo/_base/declare',
  'dojo/_base/lang',
  'dojo/_base/array',
  'dojo/_base/html',
  'dojo/query',
  'dojo/topic',
  'dojo/on',
  'dojo/aspect',
  'dojo/keys',
  'dojo/i18n',
  'dojo/_base/config',
  'esri/dijit/InfoWindow',
  'esri/dijit/PopupMobile',
  'esri/InfoTemplate',
  'esri/request',
  'esri/arcgis/utils',
  'esri/geometry/Extent',
  'esri/geometry/Point',
  'require',
  './utils',
  'jimu/LayerInfos/LayerInfos',
  'jimu/dijit/Message',
  'jimu/dijit/AppStatePopup',
  './MapUrlParamsHandler',
  './AppStateManager',
  './PopupManager',
  './FilterManager'
], function(declare, lang, array, html, query, topic, on, aspect, keys, i18n, dojoConfig, InfoWindow,
  PopupMobile, InfoTemplate, esriRequest, arcgisUtils, Extent, Point, require, jimuUtils,
  LayerInfos, Message, AppStatePopup, MapUrlParamsHandler, AppStateManager, PopupManager, FilterManager) {
  var instance = null,
    clazz = declare(null, {
      appConfig: null,
      mapDivId: '',
      map: null,
      previousInfoWindow: null,
      mobileInfoWindow: null,
      isMobileInfoWindow: false,
     layerInfosObj: null,
     SERVICE_ID: "_M",
      constructor: function( /*Object*/ options, mapDivId) {
        this.appConfig = options.appConfig;
        this.urlParams = options.urlParams;
        this.mapDivId = mapDivId;
        this.id = mapDivId;
        this.appStateManager = AppStateManager.getInstance(this.urlParams);
        this.popupManager = PopupManager.getInstance(this);
        this.filterManager = FilterManager.getInstance();
        this.nls = window.jimuNls;
        topic.subscribe("appConfigChanged", lang.hitch(this, this.onAppConfigChanged));
        topic.subscribe("syncExtent", lang.hitch(this, this.onSyncExtent));
        topic.subscribe("mapContentModified", lang.hitch(this, this.onMapContentModified));
        on(window, 'resize', lang.hitch(this, this.onWindowResize));
        on(window, 'beforeunload', lang.hitch(this, this.onBeforeUnload));
      showMap: function() {
        // console.timeEnd('before map');
        this._showMap(this.appConfig);
      _showMap: function(appConfig) {
        console.time('Load Map');
        //for now, we can't create both 2d and 3d map
        if (appConfig.map['3D']) {
          if (appConfig.map.itemId) {
            this._show3DWebScene(appConfig);
          } else {
            this._show3DLayersMap(appConfig);
        } else {
            this._show2DWebMap(appConfig);
          } else {
            console.log('No webmap found. Please set map.itemId in config.json.');
      onBeforeUnload: function() {
        if(this.appConfig.keepAppState) {
          this.appStateManager.saveWabAppState(this.map, this.layerInfosObj);
      onWindowResize: function() {
        if (this.map && this.map.resize) {
          this.map.resize();
          this.resetInfoWindow(false);
      getMapInfoWindow: function(){
        return {
          mobile: this._mapMobileInfoWindow,
          bigScreen: this._mapInfoWindow
      resetInfoWindow: function(isNewMap) {
        if(isNewMap){
          this._mapInfoWindow = this.map.infoWindow;
          if(this._mapMobileInfoWindow){
            this._mapMobileInfoWindow.destroy();
            // working around for bug of destroying _mapMobileInfoWindow is not completely.
            query("div.esriMobileInfoView.esriMobilePopupInfoView").forEach(function(node){
              html.destroy(node);
            query("div.esriMobileNavigationBar").forEach(function(node){
              html.destroy(node);
          this._mapMobileInfoWindow =
          new PopupMobile(null, html.create("div", null, null, this.map.root));
          this.isMobileInfoWindow = false;
        if (jimuUtils.inMobileSize() && !this.isMobileInfoWindow) {
          this.map.infoWindow.hide();
          this.map.setInfoWindow(this._mapMobileInfoWindow);
          this.isMobileInfoWindow = true;
        } else if (!jimuUtils.inMobileSize() && this.isMobileInfoWindow) {
          this.map.setInfoWindow(this._mapInfoWindow);
      onSyncExtent: function(map){
        if(this.map){
          var extJson = map.extent;
          var ext = new Extent(extJson);
          this.map.setExtent(ext);
      _visitConfigMapLayers: function(appConfig, cb) {
        array.forEach(appConfig.map.basemaps, function(layerConfig, i) {
          layerConfig.isOperationalLayer = false;
          cb(layerConfig, i);
        }, this);
        array.forEach(appConfig.map.operationallayers, function(layerConfig, i) {
          layerConfig.isOperationalLayer = true;
          cb(layerConfig, i);
        }, this);
      _show3DLayersMap: function(appConfig) {
        require(['esri3d/Map'], lang.hitch(this, function(Map) {
          var initCamera = appConfig.map.mapOptions.camera,
            map;
          map = new Map(this.mapDivId, {
            camera: initCamera
          this._visitConfigMapLayers(appConfig, lang.hitch(this, function(layerConfig) {
            this.createLayer(map, '3D', layerConfig);
          map.usePlugin = Map.usePlugin;
          this._publishMapEvent(map);
      _show3DWebScene: function(appConfig) {
        this._getWebsceneData(appConfig.map.itemId).then(lang.hitch(this, function(data) {
            var map = new Map(this.mapDivId, appConfig.map.mapOptions);
            array.forEach(data.itemData.operationalLayers, function(layerConfig) {
            }, this);
            array.forEach(data.itemData.baseMap.baseMapLayers, function(layerConfig) {
              layerConfig.type = "tile";
            }, this);
            array.forEach(data.itemData.baseMap.elevationLayers, function(layerConfig) {
              layerConfig.type = "elevation";
            }, this);
            map.toc = data.itemData.toc;
            map.bookmarks = data.itemData.bookmarks;
            map.tours = data.itemData.tours;
/*	function PopupCenter(url, title, w, h) {
    // Fixes dual-screen position                         Most browsers      Firefox
    var dualScreenLeft = window.screenLeft != undefined ? window.screenLeft : screen.left;
    var dualScreenTop = window.screenTop != undefined ? window.screenTop : screen.top;
    width = window.innerWidth ? window.innerWidth : document.documentElement.clientWidth ? document.documentElement.clientWidth : screen.width;
    height = window.innerHeight ? window.innerHeight : document.documentElement.clientHeight ? document.documentElement.clientHeight : screen.height;
    var left = ((width / 2) - (w / 2)) + dualScreenLeft;
    var top = ((height / 2) - (h / 2)) + dualScreenTop;
    var newWindow = window.open(url, title, 'scrollbars=yes, width=' + w + ', height=' + h + ', top=' + top + ', left=' + left);
    // Puts focus on the newWindow
    if (window.focus) {
        newWindow.focus();
  _publishMapEvent: function(map) {
        topic.subscribe('toggleChanged', lang.hitch(this, function(visible, layer){
          if(visible && layer.title=='_M'||layer.title=='_M2'){
            this.SERVICE_ID = layer.title;
		// create node for the tooltip
         var tip = "Click on problem location";
         var tooltip = dojo.create("div", { "class": "tooltip", "innerHTML": tip, "style": "color: red; font-size:22px;width:200px"}, map.container);
          dojo.style(tooltip, "position", "fixed");
          // update the tooltip as the mouse moves over the map
          dojo.connect(map, "onMouseMove", function(evt) {
            var px, py;
            if (evt.clientX || evt.pageY) {
              px = evt.clientX;
              py = evt.clientY;
            } else {
              px = evt.clientX + dojo.body().scrollLeft - dojo.body().clientLeft;
              py = evt.clientY + dojo.body().scrollTop - dojo.body().clientTop;
            // dojo.style(tooltip, "display", "none");
            tooltip.style.display = "none";
            dojo.style(tooltip, { left: (px + 15) + "px", top: (py) + "px" });
            // dojo.style(tooltip, "display", "");
            tooltip.style.display = "";
            // console.log("updated tooltip pos.");
          // hide the tooltip the cursor isn't over the map
          dojo.connect(map, "onMouseOut", function(evt){
        //add this property for debug purpose
        window._viewerMap = map;
        MapUrlParamsHandler.postProcessUrlParams(this.urlParams, map);
        console.timeEnd('Load Map');
        if (this.map) {
          this.map = map;
          this.resetInfoWindow(true);
          console.log('map changed.');
          topic.publish('mapChanged', this.map, this.layerInfosObj);
        } else {
          this.map = map;
          topic.publish('mapLoaded', this.map, this.layerInfosObj);
        require([
          'esri/graphic',
          'esri/symbols/SimpleMarkerSymbol',
          'esri/symbols/SimpleLineSymbol',
          'esri/Color'
		lang.hitch(this, function(Graphic, SimpleMarkerSymbol, SimpleLineSymbol, Color){
          var symbol = new SimpleMarkerSymbol(
         SimpleMarkerSymbol.STYLE_CIRCLE, 0.01,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_CIRCLE,
            new Color([207, 16, 45, 0.9]),
          map.on("click", lang.hitch(this, function(evt){
            var gra = new Graphic(evt.mapPoint, symbol);
            setTimeout(lang.hitch(this, function(){
              var selFeats = map.infoWindow.features;
              if(!selFeats){
                map.graphics.clear();
                map.graphics.add(gra);
				//PopupCenter('http://www.xtf.dk','xtf','900','500');
                map.infoWindow.setContent('<a href="https://survey123.arcgis.com/share/xyz123?center='+ evt.mapPoint.getLatitude().toString() + ','+ evt.mapPoint.getLongitude().toString() + '&field:Floor_Selection=' + this.SERVICE_ID.split('_')[1]+"_Floor " + '" target="_"><font size="4">Click here to submit a service request</font></a>');
				SERVICE_ID: null;
                map.infoWindow.show(evt.mapPoint);
            }), 1000);
      _getWebsceneData: function(itemId) {
        return esriRequest({
          url: 'http://184.169.133.166/sharing/rest/content/items/' + itemId + '/data',
          handleAs: "json"
      _show2DWebMap: function(appConfig) {
        //should use appConfig instead of this.appConfig, because appConfig is new.
        // if (appConfig.portalUrl) {
        //   var url = portalUrlUtils.getStandardPortalUrl(appConfig.portalUrl);
        //   agolUtils.arcgisUrl = url + "/sharing/content/items/";
        if(!appConfig.map.mapOptions){
          appConfig.map.mapOptions = {};
        var mapOptions = this._processMapOptions(appConfig.map.mapOptions) || {};
        mapOptions.isZoomSlider = false;
        var webMapPortalUrl = appConfig.map.portalUrl;
        var webMapItemId = appConfig.map.itemId;
        var webMapOptions = {
          mapOptions: mapOptions,
          bingMapsKey: appConfig.bingMapsKey,
          usePopupManager: true
        if(!window.isBuilder && !appConfig.mode && appConfig.map.appProxy &&
            appConfig.map.appProxy.mapItemId === appConfig.map.itemId) {
          var layerMixins = [];
          array.forEach(appConfig.map.appProxy.proxyItems, function(proxyItem){
            if (proxyItem.useProxy && proxyItem.proxyUrl) {
              layerMixins.push({
                url: proxyItem.sourceUrl,
                mixin: {
                  url: proxyItem.proxyUrl
          if(layerMixins.length > 0) {
            webMapOptions.layerMixins = layerMixins;
        var mapDeferred = this._createWebMapRaw(webMapPortalUrl, webMapItemId, this.mapDivId, webMapOptions);
        mapDeferred.then(lang.hitch(this, function(response) {
          var map = response.map;
          //hide the default zoom slider
          map.hideZoomSlider();
          // set default size of infoWindow.
          map.infoWindow.resize(270, 316);
          //var extent;
          map.itemId = appConfig.map.itemId;
          map.itemInfo = response.itemInfo;
          map.webMapResponse = response;
          // enable snapping
          var options = {
            snapKey: keys.copyKey
          map.enableSnapping(options);
          html.setStyle(map.root, 'zIndex', 0);
          map._initialExtent = map.extent;
          this.layerInfosObj = LayerInfos.getInstanceSyncForInit(map, map.itemInfo);
          //save layer's original refreshInterval
          this.layerInfosObj.traversalLayerInfosOfWebmap(lang.hitch(this, function(layerInfo){
            layerInfo.getLayerObject().then(lang.hitch(this, function(layerObject){
              if(layerObject){
                lang.setObject("_wabProperties.originalRefreshinterval", layerObject.refreshInterval, layerObject);
            }), lang.hitch(this, function(err){
              console.error("can't get layerObject", err);
          if(appConfig.map.mapRefreshInterval && !appConfig.map.mapRefreshInterval.useWebMapRefreshInterval){
            this._updateRefreshInterval(appConfig.map.mapRefreshInterval);
          this._showUnreachableLayersTitleMessage();
          setTimeout(lang.hitch(this, this._checkAppState), 500);
          this._addDataLoadingOnMapUpdate(map);
        }), lang.hitch(this, function(error) {
          console.error(error);
          this._showError(error);
          topic.publish('mapCreatedFailed');
      _handleRefreshLayer: function(featureLayer){
        // var layerId = "Wildfire_5334";
        //before refresh => update-start => after refresh => get data => graphic-remove => graphic-add => update-end
        var _drawFeatures = featureLayer._mode._drawFeatures;
        var _clearIf = featureLayer._mode._clearIIf;
        var _cellMap = null;
        featureLayer._mode._drawFeatures = function(response, cell) {
          /*jshint unused: false*/
          // console.log(response);
          if (cell && typeof cell.row === 'number' && typeof cell.col === 'number') {
            featureLayer._mode._removeCell(cell.row, cell.col);
          _drawFeatures.apply(featureLayer._mode, arguments);
        aspect.before(featureLayer, 'refresh', function() {
          // console.log("before refresh");
          _cellMap = featureLayer._mode._cellMap;
          featureLayer._mode._clearIIf = function() {};
        aspect.after(featureLayer, 'refresh', function() {
          // console.log("after refresh");
          featureLayer._mode._cellMap = _cellMap;
          featureLayer._mode._clearIIf = _clearIf;
        on(featureLayer, 'update-start', function(){
          // console.log('update-start');
          featureLayer.isUpdating = true;
        on(featureLayer, 'update-end', function(){
          // console.log('update-end');
          featureLayer.isUpdating = false;
        // on(featureLayer, 'graphic-add', function(){
        //   console.log('graphic-add');
        // on(featureLayer, 'graphic-remove', function(){
        //   console.log('graphic-remove');
        // on(featureLayer, 'graphics-clear', function(){
        //   console.log('graphics-clear');
      _showError: function(err){
        if(err && err.message){
          html.create('div', {
            'class': 'app-error',
            innerHTML: err.message
          }, document.body);
      _createWebMapRaw: function(webMapPortalUrl, webMapItemId, mapDivId,  webMapOptions){
        var mapDef = jimuUtils.createWebMap(webMapPortalUrl, webMapItemId, mapDivId, webMapOptions);
        return mapDef.then(lang.hitch(this, function(response){
          return response;
        }), lang.hitch(this, function(error){
          if(error && error instanceof Error && error.message){
            var cache = i18n.cache;
            var key = "esri/nls/jsapi/" + dojoConfig.locale;
            /*if(dojoConfig.locale !== 'en'){
              key += "/" + dojoConfig.locale;
            var esriLocaleNls = cache[key];
            var str = lang.getObject("arcgis.utils.baseLayerError", false, esriLocaleNls);
            if(str && error.message.indexOf(str) >= 0){
              //The original basemap is not available. We can create the webmap with another basemap layer.
              new Message({
                message: window.jimuNls.map.basemapNotAvailable + window.jimuNls.map.displayDefaultBasemap
              return arcgisUtils.getItem(webMapItemId).then(lang.hitch(this, function(itemInfo){
                itemInfo.itemData.spatialReference = {
                  wkid: 102100,
                  latestWkid: 3857
                itemInfo.itemData.baseMap = {
                  baseMapLayers: [{
                    url: "http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer",
                    opacity: 1,
                    layerType: "ArcGISTiledMapServiceLayer",
                    visibility: true,
                  title: "Topographic"
                return jimuUtils.createWebMap(webMapPortalUrl, itemInfo, mapDivId, webMapOptions);
          throw error;
      _showUnreachableLayersTitleMessage: function() {
        var unreachableLayersTitle = this.layerInfosObj.getUnreachableLayersTitle();
        var layersTitleString = "";
        var message = window.jimuNls.map.layerLoadedError ||
          "The layer, ${layers} cannot be added to the map.";
        if(message && unreachableLayersTitle && unreachableLayersTitle.length > 0) {
          array.forEach(unreachableLayersTitle, lang.hitch(this, function(title) {
            layersTitleString = layersTitleString +  title + ", ";
          new Message({
            message: message.replace("${layers}", layersTitleString)
      _addDataLoadingOnMapUpdate: function(map) {
        var loadHtml = '<div class="map-loading">Loading...</div>';
        var loadContainer = html.toDom(loadHtml);
        html.place(loadContainer, map.root);
        if(map.updating){
          html.addClass(loadContainer, 'loading');
        on(map, 'update-start', lang.hitch(this, function() {
        on(map, 'update-end', lang.hitch(this, function() {
          html.removeClass(loadContainer, 'loading');
        on(map, 'unload', lang.hitch(this, function() {
          html.destroy(loadContainer);
          loadContainer = null;
      _checkAppState: function() {
        //URL parameters that affect map extent
        var urlKeys = ['extent', 'center', 'marker', 'find', 'query', 'scale', 'level'];
        var useAppState = this.appConfig.keepAppState;
        if(useAppState) {
          array.forEach(urlKeys, function(k){
            if(k in this.urlParams){
              useAppState = false;
          }, this);
        if(useAppState){
          this.appStateManager.getWabAppState().then(lang.hitch(this, function(stateData) {
            if (stateData.extent || stateData.layers) {
              var appStatePopup = new AppStatePopup({
                nls: {
                  title: this.nls.appState.title,
                  restoreMap: this.nls.appState.restoreMap
              appStatePopup.placeAt('main-page');
              on(appStatePopup, 'applyAppState', lang.hitch(this, function() {
                this._applyAppState(stateData, this.map);
              appStatePopup.startup();
              appStatePopup.show();
      _applyAppState: function(stateData, map) {
        var layerOptions = stateData.layers;
        this.layerInfosObj.restoreState({
          layerOptions: layerOptions || null
        if (stateData.extent) {
          map.setExtent(stateData.extent);
      _processMapOptions: function(mapOptions) {
        if (!mapOptions) {
          return;
        if(!mapOptions.lods){
          delete mapOptions.lods;
        if(mapOptions.lods && mapOptions.lods.length === 0){
        var ret = lang.clone(mapOptions);
        if (ret.extent) {
          ret.extent = new Extent(ret.extent);
        if (ret.center && !lang.isArrayLike(ret.center)) {
          ret.center = new Point(ret.center);
        if (ret.infoWindow) {
          ret.infoWindow = new InfoWindow(ret.infoWindow, html.create('div', {}, this.mapDivId));
        return ret;
      createLayer: function(map, maptype, layerConfig) {
        var layMap = {
          '2D_tiled': 'esri/layers/ArcGISTiledMapServiceLayer',
          '2D_dynamic': 'esri/layers/ArcGISDynamicMapServiceLayer',
          '2D_image': 'esri/layers/ArcGISImageServiceLayer',
          '2D_feature': 'esri/layers/FeatureLayer',
          '2D_rss': 'esri/layers/GeoRSSLayer',
          '2D_kml': 'esri/layers/KMLLayer',
          '2D_webTiled': 'esri/layers/WebTiledLayer',
          '2D_wms': 'esri/layers/WMSLayer',
          '2D_wmts': 'esri/layers/WMTSLayer',
          '3D_tiled': 'esri3d/layers/ArcGISTiledMapServiceLayer',
          '3D_dynamic': 'esri3d/layers/ArcGISDynamicMapServiceLayer',
          '3D_image': 'esri3d/layers/ArcGISImageServiceLayer',
          '3D_feature': 'esri3d/layers/FeatureLayer',
          '3D_elevation': 'esri3d/layers/ArcGISElevationServiceLayer',
          '3D_3dmodle': 'esri3d/layers/SceneLayer'
        require([layMap[maptype + '_' + layerConfig.type]], lang.hitch(this, function(layerClass) {
          var layer, infoTemplate, options = {},
            keyProperties = ['label', 'url', 'type', 'icon', 'infoTemplate', 'isOperationalLayer'];
          for (var p in layerConfig) {
            if (keyProperties.indexOf(p) < 0) {
              options[p] = layerConfig[p];
          if (layerConfig.infoTemplate) {
            infoTemplate = new InfoTemplate(layerConfig.infoTemplate.title,
              layerConfig.infoTemplate.content);
            options.infoTemplate = infoTemplate;
            layer = new layerClass(layerConfig.url, options);
            if (layerConfig.infoTemplate.width && layerConfig.infoTemplate.height) {
              aspect.after(layer, 'onClick', lang.hitch(this, function() {
                map.infoWindow.resize(layerConfig.infoTemplate.width,
                  layerConfig.infoTemplate.height);
              }), true);
          } else {
          layer.isOperationalLayer = layerConfig.isOperationalLayer;
          layer.label = layerConfig.label;
          layer.icon = layerConfig.icon;
          map.addLayer(layer);
      onAppConfigChanged: function(appConfig, reason, changedJson) {
        // jshint unused:false
        this.appConfig = appConfig;
        if(reason === 'mapChange'){
          this._recreateMap(appConfig);
        }else if(reason === 'mapOptionsChange'){
          if(changedJson.lods){
        }else if(reason === 'mapRefreshIntervalChange'){
          var itemData = this.map && this.map.itemInfo.itemData;
          if (itemData && this.layerInfosObj) {
            this._updateRefreshInterval(changedJson);
      onMapContentModified: function() {
        this._recreateMap(this.appConfig);
      _updateRefreshInterval: function(refreshInterval){
        var minutes = -1;
        if (refreshInterval.useWebMapRefreshInterval) {
          //Honor the individual interval of each layer
          minutes = -1;
        } else {
          //Use a single interval for all layers
          minutes = refreshInterval.minutes;
        this.layerInfosObj.traversalLayerInfosOfWebmap(lang.hitch(this, function(layerInfo) {
          layerInfo.getLayerObject().then(lang.hitch(this, function(layerObject) {
            if(!layerObject){
              return;
            //only handle non-static layer
            var originalRefreshinterval = lang.getObject("_wabProperties.originalRefreshinterval", false, layerObject);
            if(originalRefreshinterval > 0){
              if (typeof layerObject.setRefreshInterval === 'function') {
                if (minutes < 0) {
                  layerObject.setRefreshInterval(originalRefreshinterval);
                } else {
                  layerObject.setRefreshInterval(minutes);
          }), lang.hitch(this, function(err) {
      _recreateMap: function(appConfig){
        if(this.map){
          topic.publish('beforeMapDestory', this.map);
          this.map.destroy();
        this._showMap(appConfig);
      disableWebMapPopup: function() {
        this.map.setInfoWindowOnClick(false);
      enableWebMapPopup: function() {
        this.map.setInfoWindowOnClick(true);
  clazz.getInstance = function(options, mapDivId) {
    if (instance === null) {
      instance = new clazz(options, mapDivId);
    return instance;
  return clazz;
Joe,
joerodmey
I've added the widget successfully and into my app. But when I click on the app to fire it up it just hangs on loading bubbles.
Worked for me when I was developing it...
joerodmey
I added it into my sitemap folder and shows properly in the app. But when I click to load the popup it shows the widget window with icon and textbox at top but rest of screen is blank
And errors in the browser say?
joerodmey
joerodmey
Error screenshot attached
