Canvas height keep increasing
1868
7
04-26-2021 02:33 AM
GiovanniVanore1
New Contributor II
Hello All,
I am facing issue while using Arcgis/core 4.18. My map canvas height keep increasing. I am using Arcgis/Core with Angular 11.
Here is my code
app.component.html
<html>
  <head>
  </head>
  <body>
      <div id="viewDiv"></div>
  </body>
</html>
app-component.css
#viewDiv {
    padding0;
    margin0;
    height100%;
    width100%;
app-component.ts
import { Component,OnInit,AfterViewInit } from '@angular/core';
import { ArcgisService } from './arcgis.service';
import MapView from '@arcgis/core/views/MapView'
import config from '@arcgis/core/config';
import Map from '@arcgis/core/Map';
@Component({
  selector: 'app-root',
  templateUrl: './app.component.html',
  styleUrls: ['./app.component.scss']
export class AppComponent  {
  title = 'sampleProgram';
  constructor(public arcgis:ArcgisService) {
  ngOnInit() {
    //this.arcgis.initMap();
    this.initMap();
  ngAfterViewInit(){
    //this.initMap();
  initMap(){
    config.assetsPath = './assets';
    const map = new Map({
      basemap: "arcgis-topographic" //Basemap layer service
    // Create a MapView instance (for 2D viewing) and reference the map instance
    const view = new MapView({
      map: map,
      center: [-118.8050034.02700], //Longitude, latitude
      zoom: 13,
      container: "viewDiv"
    view.when(() => console.log('view ready'));
Install npm arcgis/core
AndyGup
Hi @GiovanniVanore1 this doesn't sounds like it's related to the ArcGIS API for JavaScript. Can you provide a simple github repo that reproduces the issue?
GiovanniVanore1
New Contributor II
ReneRubalcava
I've seen this happen if you don't have the CSS for the ArcGIS JSAPI included in your application.
GiovanniVanore1
New Contributor II
@ReneRubalcava Yes, I have added ArcGIS JSAPI . Still getting same issue
AndyGup
@GiovanniVanore1 I'm not sure what's going on, I tried just about everything to get the app running right. My recommendation is to start fresh using our Angular sample app: https://github.com/Esri/jsapi-resources/tree/master/esm-samples/jsapi-angular-cli.
Frédéric_ALBERT
New Contributor II
I took a quick look at your code. There are several issues.
The main one (causing the endless div resize) is this:
@import "@arcgis/core/assets/esri/themes/light/main.css";
Should be in your main styles.scss. Not in the scope of your app.component scss.
Secondly, your app layout is not good if you wish a fullscreen map application.
Your styles.scss file should contain something like:
html, body { height: 100%; }
Then your app.component.html file mention a html-head-body hierarchy that is already in index.html.
This is screwing your vertical positioning.
Keep it simple like this:
{{title}}
<router-outlet></router-outlet>
GiovanniVanore1
New Contributor II
Yes finally its resolved by Js-api and its working fine  Thanks a lot guys.
