Can I use firefly symbols within the ArcGIS API for JavaScript 4 renderer?
1757
04-08-2018 12:02 PM
DennisPayk
New Contributor II
I would like to use firefly symbols like described here What’s New in ArcGIS Online? Firefly! - ArcGIS Blog  within a renderer in the ArcGIS API for JavaScript to render symbols from a point Feature Layer. Is this possible somehow?
KellyHutchins
Esri Frequent Contributor
Sure you can do this. I think the easiest way would be to symbolize your map using the ArcGIS Online Map Viewer then save the web map and look at the network traffic and view the web map json. You can then pull that info into your jsapi app. Here's an simple web map that uses the firefly symbol.
http://www.arcgis.com/sharing/rest/content/items/e2a892af27d94d6fb03e9d51b4f74d59/data?f=json
And here's a test app that uses the same symbology:
JS Bin - Collaborative JavaScript Debugging
KellyHutchins
JinnanZhang1
Here is a simple app that you can use to generate the firefly symbols that can be used with ArcGIS JS API:
https://vannizhang.github.io/firefly-symbols-generator/dist/
RyanBohan
Occasional Contributor III
What a great app, thank you.  Love the way the colors are displayed
