I am trying to modify the WebTileLayer 3d example (WebTileLayer 3D | ArcGIS API for JavaScript 4.1) to use the tiles at this address:
http://tiles.gina.alaska.edu/tiles/SPOT5.SDMI.ORTHO_RGB/tile/{x}/{y}/{z}.png
and I end up with the code below but the tiles never get loaded. They load just fine in a Cesium web globe app so I know they should work. Can anyone help me troubleshoot this?
<!DOCTYPE html> <html> <head> <meta charset="utf-8"> <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no"> <title>WebTileLayer 3D - 4.1</title> <style> html, body, #viewDiv { padding: 0; margin: 0; height: 100%; width: 100%; } </style> <link rel="stylesheet" href="https://js.arcgis.com/4.1/esri/css/main.css"> <script src="https://js.arcgis.com/4.1/"></script> <script> require([ "esri/config", "esri/layers/WebTileLayer", "esri/Map", "esri/views/SceneView", "dojo/dom", "dojo/domReady!" ], function(esriConfig, WebTileLayer, Map, SceneView, dom) { esriConfig.request.corsEnabledServers .push("a.tile.stamen.com", "b.tile.stamen.com", "c.tile.stamen.com", "d.tile.stamen.com"); var map = new Map({ ground: "world-elevation" }); var view = new SceneView({ container: "viewDiv", map: map, scale: 10000000, center: [-154, 62] }); var tiledLayer = new WebTileLayer({ urlTemplate: "http://tiles.gina.alaska.edu/tiles/SPOT5.SDMI.ORTHO_RGB/tile/{col}/{row}/{level}.png", }); map.add(tiledLayer); }); </script> </head> <body> <div id="viewDiv"></div> </body> </html>
Solved! Go to Solution.
Hi Evan
it looks like you are missing to add your server to CORS (see config | API Reference | ArcGIS API for JavaScript 4.1).
When you add the following to your code, tiles should be loading:
esriConfig.request.corsEnabledServers.push("http://tiles.gina.alaska.edu");
I hope this helps.
Kind regards
Veronika
Hi Evan
I hope this helps.
Kind regards
Veronika
Excellent! Thank you!
