Bug in the sample "Swap web maps in the same view" with mapservices
420
08-06-2019 04:30 AM
AxelLévy
New Contributor III
Hi all,
https://developers.arcgis.com/javascript/latest/sample-code/webmap-swap/index.html
I use this sample to display several webmaps. it works well when the layers are featurelayers. When it's mapservices, the webmap does not reload completely after a tab change. Only the base map is displayed and I need to zoom or pan to display the data.
If you want to see the issue, you can use this webmap in the sandbox
require(["esri/views/MapView", "esri/WebMap"], function(MapView, WebMap) {
var webmapids = [
"c7ca72f617ff45bb9e891aeaf5150952",
Can someone help me? Thank you
BenElan
I can repro. Also an issue in 4.11. Does this happen when the webmaps are all different?
AxelLévy
New Contributor III
Hello Ben
Yes it happens also with different webmaps.
AxelLévy
New Contributor III
Hi, I'm still looking for a solution or a workaround if someone has an idea
BenElan
I suggest contacting Esri Support Services to report this bug.
https://support.esri.com/en/contact-tech-support
